He had something unavoidable come up that caused him to cancel, I do not blame him at all, I would of done the same thing. I would of refunded any deposit under the circumstances anyways lol.
Mostly trying to clean some stuff up and tax time just hit me harder then expected, so could use some extra cash.
You can use a phone, but if you can swing roughly $100 to $150 for a used data logger, get that. Much easier to use and if you get a calibrated one it will be more accurate.
Make sure you calibrate it with lights with honest factory ratings (Nightwatch, thrunite, Olight, Rovyvon, Fenix, Speras are pretty trustworthy).
My version has stayed the same without need for re-cal.
Like +/- 2 Lumens on a 1000 Lumen light. And maybe it’s the light that changed, not the tube?
Unless I fuss with it - then all bets are off. My version can be re-calibrated easily because of the design.
Any mod will make a difference. Just let it be, and it should be consistent.
Watch out for changes in room lighting. Keep it constant over time.
A few lumens can sneak into the tubes, more or less, unless they are shielded somehow.
All the Best,
Jeff
Largely depends on what you can find, I found a massive 4x8 diffusion sheet at a local place I have been using for my builds just cutting pieces off it little by little. In fact I need to check how much I have left come to think of it.
I found an opaqe diffusion to work best, all the clear ones I tried just didn’t seem to work as well. I did find one that worked but it took twice as many layers and even then it just didn’t feel as consistent with different beam profiles.
Mostly you want something that won’t melt but also lets enough light through that you can get a reading through 2-4 layers but not so much you have to drastically reduce the readings.
thanks Texas_Ace :+1:
i think i have some old fixtures laying around.
i know these are meant for flashlights, but how would they work for light bulbs?
i’m planning on doing some hacking to lower the heat of some cheap bulbs.
Depends on the bulb I guess, no idea if the calibration would be correct or not but if only the LED’s were exposed to the inside of the tube and there was nothing dark to absorb light, it might work ok.
right on. i don’t plan on calibrating anything as i’ll just be measuring lights relative to themselves and plotting run time for flashlights.
gonna give this build a go.
