I’m all in for the 5,600lm sustained but at only 30kcd makes it not ideal for outdoor use. I’d much rather have lower max output and more usable throw like the manker MK38 with the SFT40 option. Maybe SFT70 or XHP.70.3 HI?
In the Q&A section, I see "7. Can I use the X50 battery pack to DIY other products I need?". This suggests that it can be removed and thus, replaceable?
Acebeam X50 2.0 is built-In Lithium Ion Battery Pack (3pcs x 21700) with power protection plates emphasize high performance and safety.The battery pack is removable for easy replacement.
If you are looking for the reliable power bank flashlight, the Acebeam “X50 2.0” world’s first PD power bank flashlight with 45,000lumens is absolutely your perfect choice.
[Ultra Bright Flashlight] Delivers a an amazing 45,000 lumens of light 2,857.6 feet/871 meters
[Adopts 8pcs x LED Emitters] Available 3 different LED color temperature Cool White, Natural White, and High CRI Emitters for options.
[Small Size,Great Competence] The light is measured at a length of 5.49 inches,slides easily in your palm, pocket, and bag.
[PD60W Fast Charge] The world’s fast charging power bank flashlight can be fully charged in less than an hour.
[High-Efficiency USB-C] Equipped with the latest worldwide USBC charging standard, it also works as a power bank for mobile phones,camera,notebook and other devices.
[Premium Quality] IP68 Rated Protection,fully protected against dust and foreign objects,Waterproof underwater to 2 meters.
[High Performance] Built-In Lithium Ion Battery Pack (3pcs x 21700) with power protection plates emphasize high performance and safety.The battery pack is removable for easy replacement.
[Intelligent Safety Protection] Supports Over-Charged, Over-Discharged, Over-Voltage and Short Circuit Protection,more safe to use.
[Portable & Durable Design] Can be used for outdoor exploration,camping, emergency lighting and provided long runtime bright lighting.
At ACEBEAM,There are more New, Unique and Innovative flashlights releasing in 2022.The new items will be used different emitters.Please stay tuned for our new release products in next days.
The SFT40 emitter focus on throw, but can not increase much brightness.We will have New and Innovative flashlights which will be used the new emitters. Please stay tuned for the new releases.
It looks like the USB port requires unscrewing the tail cap, which seems like a good improvement over the rubber flap port on the X50. A bit more awkward to access but more waterproof.
