NEW high current 60V 24A 1440W power supply RD6024 is released now
RD6006 feedback
good product, and finally I got my own power supply
https://www.aliexpress.com/item/4000282551930.html
RD6024 feedback
Everything was packed in a foam box, so it arrived without damage. Completeness and quality are 100% consistent with the description on the seller's website. The seller responds quickly. I recommend to other buyers
www.aliexpress.com/item/1005003744641750.html
RD6018 feedback
Product just as the discription
https://www.aliexpress.com/item/1005001488070904.html
RD6006 feedback
Everything is great! Very quickly delivered by DPD service directly to the house.
hello,if you use your own PSU for our power supplies, please notice the output of the PSU, do not let it higher than the input limit of our power supplies, and it is necessory to test if the PSU has stable output, if it has over-voltage peak, it is also not suitable.
RD6006W feedback
Product arrived as agreed, well packed. Recommend. Excellent product.
RD6012W feedback
Thank you very, very, very much, it took 2 weeks to get to Canada :), great packaging ( it was in a bigger foam box not shown in the picture, even got a very nice pen and got all the parts, just need to try it out.
https://www.aliexpress.com/item/4001053200176.html
Hello, today is the final work day in April, and we will have a 5-Day national holiday, during this time, we do not work, and we do not send packages from our China warehouse, please notice that we will send the package from May 5th
RD6006W feedback
very good I liked it a lot
hello, if your RD device is damaged, you can contact us for help, we can see if it can be repaired, sometimes just the fuse burnt, you can replace the fuse and it is ok, and like this customer, the screen is damaged, we send him the screen and video instruction to fix, it is ok
RD6006P feedback
power supply is excellent! packaged very carefully! From the back, the circuit design is very compact and elegant, and the workmanship is fine. It took about two hours to assemble at night (please see first Instructions will save time)
www.aliexpress.com/item/1005002185722889.html
RD6018 feedback
There are no problems with delivery and packaging. Thanks seller.
RD6012 feedback
very good team .... regulates perfectly
https://aliexpress.ru/item/4001053200176.html
RD6024W feedback
I received everything, it arrived in a few days. There are no defects, I am satisfied with the purchase.
https://www.aliexpress.com/item/1005003744641750.html
RD6006P feedback
I have to say, this power supply is definitely value for money
https://www.aliexpress.com/item/1005002185722889.html
RD6018 Feedback
I have tried all the functions so far. The charging function is very good. The power supply is very useful. It solved the problem of high current. They answer all questions, The next step is to wait for the silicone wire. perfect shopping
RD6024W Feedback
Everything is fine, delivered in 3 days(From RU warehouse)
RD6024 feedback
my wooden case is not bad too,haha
I have an RD 6018. When set to 0 amps, it still passes current.
Is this normal?
All the Best,
Jeff
RD6024W feedback
Collected everything, it works. Made with high quality. Until I figured out the settings.
