JKK76 7*SFT40 and 7*SFN55.2
And now the crees are coming out with .3 that’s making for more high cri rendering.
Ok, so I’ve contacted San’an.
Let’s see how they respond :money_mouth_face:
I have enough to do one large payment. Hank’s website with PayPal is probably setup to accept payment the same way AliExpress does as a foreign transaction which is probably why mine didn’t go through.
Haven’t looked into this too much since 519A are taking a while to get to Hank
It would be hard and probably not worth the trouble unless there are cheap, established freight forwarders servicing your country. The Singaporean in this thread has used a freight forwarder with success.
I just bought myself the SFT-40 version and if it’s too throwy for my taste I’ll replace one or two of the LED’s with LH351D or something
Yep. I just checked ali, Imalent is asking for just under usd200 for its 4 * 21700 pack. what the…. Very sure that disassembling the pack without destroying it and soldering back on new cells is beyond my expertise, coz Imalent for sure would wanna protect this cash cow. Something like inkjet printer cartridges. lol.
If not, the Imalent ms12 mini is pretty decent. i guess we just have to wait for some budgetlight maker to drop in 7 or 9 pcs of the Cree into their hosts. ie Amutorch, Nightwatch or JKK. Issue is that the market for this wont be huge in China, they do support these domestic LEDs.
NW
https://shop241682067.taobao.com/shop/view_shop.htm?spm=a1z09.2.0.0.71af2e8dFao8LN&user_number_id=402098252
Jinheng
https://shop65268295.taobao.com/shop/view_shop.htm?spm=a1z09.2.0.0.71af2e8dFao8LN&user_number_id=520283139
Amu
https://amutorch.taobao.com/shop/view_shop.htm?spm=a1z0d.6639537.1997196601.214.148e7484zuEivB&user_number_id=65539984
There is one more semi decent one but not into high output flashlights.
https://dodota.taobao.com/shop/view_shop.htm?spm=a1z0d.6639537.1997196601.92.148e7484zuEivB&user_number_id=218515271
On the Road also have decent hosts/lights, but a bit lagging on its emitter options and most importantly its price sucks.
Haikelite is a neither here or there, but his HT50 @ rmb 198 doing 500kcd and 6k lumens then before the price rise is very good.
Ok people, i have gotten some data/answers with some testing from my cells. Sharing here since most are high lumen chasers here and hence battery info ought to be welcomed (even though we get it mostly from lygte/mooch/vaping community etc).
Namely my Samsung 50G, Samsung 40T, Lishen 21700LA (4000mAh) and Lishen 21700HP (3000mAh)…on the JKK76.
All cells fully charged and pretty new/new.
RAW numbers on the meter. JKK76 6500k SFN 55.2 ceiling bounce. Springs are bypassed with rolled up aluminum foil connecting top to bottom part of the spring. The foil is probably around 10 awg thereabouts, more than sufficient, stock spring is decent enough too, but not sure if capable of doing 30-33 amps.
3pcs 50G = 2100 range.
1pc = never test.
3pcs 40T = 2300 range.
1pc = 1200 range
3pcs Lishen 21700LA = 2300 range
1pc = 1200 range
3pcs Lishen 21700HP = 2300 range
1pc = 1400 range.
Obviously the driver is trying to limit pure output. Reason? Trying to protect the SFN 55.2s?
If it’s pure drive drive, i ought to be doing 4200 in theory (of coz it wont hit that in reality). ie the Lishen 21700HP should not be the limiting factor, neither should the springs……at least not for the first 1-2 seconds. So it should be able to do 33k lumens easy, if not in pure DD it should be pushing over 40k @ turn on
My Amutorch DM70 with 4pcs cree 70.2s 6500k is pushing 1900 range on the meter.
Of coz not that it matters in reality, just a useless flasholic rambling. :person_facepalming:
Jin Heng tends to be quite conservative with their drivers.
Ok my bad….i re-checked the official info and 33k lumens turbo mode is not direct drive.
直驱 = direct drive according to my understanding, and also according to google translate.
恒流 = constant current
I wonder what it really means when they put 直驱 on that line regarding 450m illum distance and 150k cd light intensity. It’s coz i really did come across this 直驱/direct drive words that led me to believe that the turbo is DD.
But then to be honest, 40k lumens at turn on with non-70.2 levels of efficiency on Samsung 30T or LS 21700HP is really no joke in terms of heat.
ps. Oh just thought of this. Was originally wondering if bypass improves the initial few seconds of output or not. From the data above, we can conclude that the stock springs are more than sufficient, ie don’t bother bypassing.
But using high amp cells is a must. for eg, the 15A 50G barely makes it, only consider that if you need the 5000mAh. ie very few turbo uses and that is not the main focus, > 90% in lower modes. For short hobby walks playing with Turbo mainly and runtime is not an issue, then nah…….
Actually, always bypass if you can.
Lower resistance = better battery life :smiley:
Not an electrical expert here and perhaps i am missing something, but i thought the cell does not really care in this case……
Ok put it in another way……
ie in this case of the JKK76……say we are doing 25000lm and drawing 25 amps at the head’s contacts (for eg, not sure abt exact fig), bypassing or not bypassing is still 25 amps.
Coz this is not the limiting factor. The driver is the limiting factor.
For other stuff like BLF/Sofirn Q8, then yeah. I don’t have that many lights so maybe there are even better egs.
edit - oh ok ok, i think i know what you are driving at. The slightly less resistance = battery battery run time. Not what i originally thought of “better battery life” as in “cell health”. :beer: :smiley: :smiley: Ugh……for a moment i had a brain block. lol :money_mouth_face:
Anyway, i think this would be an extremely extremely small difference.
I’m just waiting for mine in the mail but I was wondering, should my Samsung 30t be good for their high amp discharge and higher wattage than the 40t
Check my above output results for the Lishen 21700HP vs the 21700LA, 3000mAh and 4000mAh respectively (claimed). Discharge amps / light output single cell of this 21700HP results mirror that of my Samsung 40T, of coz assuming that my Samsung 40T is legit. Should be, 1200 raw on my meter ceiling bounced = 14-15k lumens OTF easy. Single cell man, no joke.
Use the 40T or similar, it’s 4000mAh and should sustain longer cumulative turbo duration and perhaps high-high mode (5000lm) cumulative duration as well.
There is no gain with using 30T or Lishen 21700HP. In other lights like the 2 cell Nightwatch Chaos, yes probably……there is output gains to be had.
In fact, i think Vapcell has a “new” 20A 5000mAh cell, not sure what is the true manufacturer/model, not an expert, but if it is indeed true 20A CDR, then that’d be really good for this JKK76 use. But i remember that is really $$$ costly. The Lishen 21700LA only costed me like usd 7 for 3 and shipping weight cost is like usd 1.50 for the 3pcs. :money_mouth_face:
@loafglenn, you’ll get more output at the beginning, but less at the end.
As found out in my test and above post……I don’t think there would be more output in the beginning. Originally i was hoping that this is true (i was even hoping for it to gun close to 40k)…… :money_mouth_face: lol. Also note the last bolded line. That is very telling already, in addition tot he 21700HP vs 21700LA figures.
1pc = never test.
1pc = 1200 range
1pc = 1200 range
1pc = 1400 range.
Note. HP = 3000mAh, LA = 4000mAh.
Oh one more thing……you ordered the 18k lm SFT40s right. In fact you might be interested in the 50Gs or similar, it should easily be sufficient for SFT40…15A cells. The SFN 55.2s are no efficiency master from what i compared with Cree 70.2s.
edit - oh sorry, that fella is Lunaloves and not you, upon checking 1 page ago. You ordered the SFN 55.2?
It took me a while to mule over which one I wanted but I ended up ordering the stf40. I really wanted high lumens but the throw is what got me.
I’m gonna see how the build is on this and if I can finesse my wife into letting me “try” the floody sfn55s.
When I say try, I’m sure she’ll make me do a catch and release with either.
The build is decent/functional. Sofirn kinda quality, is good to use. In fact i prefer the matt finishing on my black JKK76 than Sofirn’s more glossy finish. The silver version is darn pretty also. You won’t go wrong with silver.
Yep bro…really depends on what you are after and under what conditions/environments. If you do have an illumination use for farther objects, the tighter hotspot is good and more useful, other than the high cd.
Good to know that at least in your area you’d be able to sell your lights, in my country it’s nearly impossible to do so with these “unbranded” lights unless if it is rock bottom prices, read say usd 40 for a mint JKK76 with cells + charger inclusive. If this were Acebeam, it’d move fast, no doubt.
For “pointing” fun purposes, i already have like 3 lasers and one with a special beam expander.
Also as a side topic, i always have a funny feeling that i might get into trouble for pointing at other people’s apartments. So, i have been wondering if i were to get these floody high cd “throwers” then i think legally I might have a case for proving that i wasn’t trying to point at any apartment in particular or worse cars/aircrafts. No definitely i am not that kind of an a-hole :confounded: pointing at cars or worse aircrafts, but just in case. :zipper_mouth_face:
For eg my block to my nearest block is 200 metres away. I can illuminate 2-3 whole blocks solidly with my lights, namely 2pcs JKK76, 1pc Amutorch DM70, 1pc Sofirn Q8 Pro. I mean, 4 hands, my kid and mine. :partying_face: Other scenes include my son’s school and wooded areas, 20 to 40 meters away…… that one is really WTF bright, heh.
We get into low mode, double click for turbo, 5 seconds then single click to get back into low mode. heh……
Some wierd family bonding time also, i suppose. :partying_face: Rather healthy also, these flashlight hobby walks.
In my country, there are many other much more costly hobbies/activities that others dabble in….heh.
Someone asked for beamshots, apologies i could only do white wall types comparing the spots sizes.
BLF Q8 5000k and JKK76 SFN 55.2, at - 1 stop exposure and then 0.0 stop.
Q8 is SMO, JKK76 orange peel
Q8 has a pretty well defined central hotspot, JKK76 orange peel’s edges are diffused…typical beam profile of both reflector types.
