No problem icpart.
I knew the community was searched for such an LED for years, so I decided to pull up my overalls and get working!!!
Added to the interest sheet.
No problem icpart.
Bluesword, thanks for organizing this group buy.
I am interested. How would this LED be different, better/worse than the Nichia 519a?
How it’s better:
How it’s worse:
The 5050 footprint part is the most important by far: it allows us to replace so many lights that use XM-L2s/SST-40s with a better tinted less tint shifty high CRI LED.
That’s about it.
Silly me, I looked at the diagram a little too quickly noticing 2.9mm x 2.9mm not paying attention if that was the LED base or the die itself. Yup, 5050 def the biggest differentiator here. Looks like a nice find for SST/SFT40 lights that push alot of current that 3535 LED’s can’t handle.
These look great! I’m in for 20. Thanks!
Sign me up for 10x please. Merci
If you can get a Wechat contact, I can communicate with them and see if maybe they would be willing to send me a sample. Shipping should take only one day since I’m in the same city. I’m not sure if they have some available already though.
I can test lumens and candela (I’ll probably put it in a C8 size body), but can’t test CRI or tint.
@fogofwar, problem is that samples don’t exist for our specific CRI and other color don’t exist, but yes, you could check out the beam profile.
Pavlo and Rayoui have been added.
I’m interested in 5
Nice!
Do i have to sign up here or can i fill in the Google document later?
Definitely interested in a few
In for 10.
Given that there is a small gap between the dies, I can not think of a reason why there will not be a visible donut hole in the hotspot when used well focused in a smooth reflector, like we do in flashlights. It may be limited but it will be there, and an OP reflector may be needed to smooth it out.
The manufacturer may not realise that that is how a led is often used in a flashlight, as opposed to general lighting/car uses.
10 for me
In for 10.
Thx
+1 and IMO it’s necessary to test this before making any large order. If fogofwar can test a sample that would be great.
In fo 6.
Well, as for why I trust them and do not worry, similar LEDs like the XHP70/XHP50 had this problem being domed LEDs with gapped dies, but when being dedomed, the problem went away.
But yeah, that would be our best shot.
Luxeon MZ on the other hand has a hole with reflectors.
B35A too.
Wait, the B35AM has holes?
Isn’t it a singular large die with multiple small emitters all under the phosphor?
If so, that is interesting.
It has 4 E21 dies
