Looks very well made Gchart
Nicely done gchart!
What size are the pogo pins? I’ve been looking at buying some, but turns out there’s a gazilion sizes…
Big thank you! It’s useful to see your photo and know the actual type. Puts it better into perspective.
Just wanted to let people know that Sofirn and Barry have replied to me meanwhile, concerning my order. :+1:
They are expecting drivers and updating firmware, so that is what caused delay.
Sofirn mentioned the end of the month to eventually have them.
I will wait for them to become available, as will not cancel my order. I just wanted to know what would be the reason, and now I know :+1:
Gchart you mentioned that shipping to Europe is expensive, should I make some programing adapters for Europeans ? (or others actually, an international 20g enveloppe is 1.65€)
That’d be great, I’d buy one.
It’s relatively easy to hack something like this together (e.g. hot gluing pogo and modding a FTDI board), but it’s an entire different thing if it’s properly done and nice and tidy like gchart’s adapter. Certainly more durable. For small things like this, shipping costs (+ customs!!!) are often a showstopper.
Even if I don’t know how to programme, I could learn and a cable would be handy in that case !
I’d buy one from you if you decide to make them. And thanks in advance for the proposal! :+1:
Yes, please.
Ok, I already ordered 15 boards and I’ll order some other necessary parts, I already have a few micro USB to TTL boards, maybe I should get some USB-C ones next.
You mentioned that heartshrink is optional, but in any case some insulation isn’t since touching the RX connection can make the programming fail in my experience.
GCHart, are there any POGO Pin adapters left for flashing this driver?
Thank you!
5C from on. I accidentally entered momentary mode and had to google to get rid of it.
I would also like to delete 5c from off since I don’t want to accidentally enter momentary mode ever again. I have no use for it.
Got your adapter today gchart. Thanks for the quick work. Now to learn the intricacies of Buried somewhere within this thread is the necessary software and some instructions on how to use it. Would you mind linking to that post in the OP to help us all out? Thanks.
I guess I need to publish a straight-forward set of instructions. I haven’t done exactly that yet, but I do have a ton of info here: Adventures in TinyAVR 1-Series
Basically, you need to…
- Make sure you have python3 installed on your computer
- Install “pip” for python3 (it may already be installed if you have python3)
- Use pip to install the “pymcuprog” package
- Download (or compile) the hex file
- Use pymcuprog on the command line to flash the hex file. I recommend doing an erase before writing the new hex file. I have sample commands in the post I linked above.
- As an alternative to #5, instead of trying to find your serial port and typing out your own commands, I have a python script here that you can use to issue a simple command like “flash-1616.py anduril.hex” to help do the dirty work.
I recently updated the firmware on mine and I posted a tutorial on reddit
The instructions are for Windows only though.
How can I add a line for 5C to activate strobe? I believe 5C while on currently doesn’t have a function
How can I remove the mode for momentary on while off?
Much thanks to gchart and zumlin! Once I got windows to install python properly, it all just worked! gchart, the little python script works very well also.
Also, just get gchart’s pogo adapter with the resistor and diode on board, it is a bargain!
What other lights flash this way, is this the first?
:+1: This is the first light with this programming format. Sofirn (and maybe Wurkkos?) seem interest on using it on more lights, so I think we’ll probably be seeing more of it soon-ish.
I haven’t tested it but I believe you can do it as follows:
Take lines 254 to 265 from off-mode.c:
// click, click, long-click: strobe mode
#ifdef USE_STROBE_STATE
else if (event EV_click3_hold) {
set_state(strobe_state, 0);
return MISCHIEF_MANAGED;
#elif defined(USE_BORING_STROBE_STATE)
set_state(boring_strobe_state, 0);
#endif
Replace EV_click3_hold with EV_5clicks
Then stick those lines of code into ramp-mode.c (line 160 might be a good place to put it)
Remove lines 266-273 from off-mode.c
#ifdef USE_MOMENTARY_MODE
// 5 clicks: momentary mode
else if (event == EV_5clicks) {
blink_once();
set_state(momentary_state, 0);
#endif
Thanks for the clear instructions. That should get me going.
I Hope we can use the programmer in the future. Of course that will depend on the drivers having programming pads.
