The Wurkkos 26650 battery is not perfectly fit to DL70 battery tube. There is a small clearance between the battery and tube and you can hear the shaking inside while holding the Flashlight unlike with DL40 it fits well..
That is “normal” – I’ve seen battery rattle in dozens of flashlights. You need some extra space because not all batteries have the same diameter. Just wrap a piece of paper around the battery one or two times. I’m using thin plastic sheets.
Looks like the site is trying to force me to use Paypal. Creditcard options don’t work. Pity.
EDIT: finally managed ordering the light. Let’s say “intuitive” isn’t the first word I can think of describing the whole procedure. Seems like all payments to Wurkkos are run by Paypal. But at the end I managed to get the order payed with my credit card.
FYI: after a lot of to and fro with my mouse I could include the coupon “DEAL8888”. Extra 10% off. Because
I’m worth it All in all only €22.36
Heat gun or hair dryer
Strap wrenches (rubber)
Thick rubber work gloves or lid opening pads
Bench vise
The Dl70 is well sealed and glued. You just need to get the bezel off and pry out the driver. You may have to get to it from top of the LED shelf and tap it out with a bamboo skewer through the LED wire holes.
Received an email from someone called Eric from Wurkkos informing me that the UK isn’t in Europe and he’s cancelled my ordered and refunded me. That’s news to me that the UK is no longer in Europe!
I got mine yesterday. No glue on bezel. Board is screwed to the reflector. When the screws are to tight, the board gets bended. I fixed it and it is running good.
There are lots of practikal differences between Europe (48+ countries) and the European Union (EU, 27 countries). Poland, where the Wurkkos warehouse is located, belongs to both groups.
The UK has left the EU, so as far as customs are concerned it falls pretty much under the same rules as every other non-EU country like Switserland, Turkey or the USA.
A lot of people don’t know the difference. To send a light to the UK creates too much paperwork because the UK does no longer belong to the EU.
And this warehouse was obviously established to deliver within the EU.
I understand all of that, but the OP said Europe not the EU, so there was no reason to think it couldn’t be shipped to the UK. There really isn’t that much more paperwork, Hank manages it from his warehouse in Germany.
