IMALENT MR90
NEWS from GATZETEC the IMALENT GERMANY IMPORTER.
IMALENT MR90
8 pcs CREE XHP 70.2
1 pcs Luminus SBT90.2
50000 Lumen
1586 Meter Beam
Akkupack 4x21700
active cooling via fans
Coming soon: IMALENT MR90 LED Taschenlampe Flutlicht
Regards and have a nice day ! Thorsten
  • Lumens :+1:
  • Throw :+1:
  • Want :+1:
I have never seen a reflector like that with so many different sizes. It looks very cool and the beam shape should be interesting to see.
Thats an odd ball arrangement of emitters, asymmetrical? Thats a first.
Yeah, I wonder about that arrangement of emitters.
What would be the advantage of doing that?
maybe a lopsided PCB was easier to design?
no clue, but I agree that it looks very weird
link
That’s really a weird reflector.
Summary : MR90 seems to have even better cooling than the MS12 mini, bigger fans and higher airflow movement.
MS12 mini is the one that gives you that OMFG feeling in most situations, the MR90 less so.
My guess is that flood as a single word to describe things is too vague, it also has many “levels” in between.
The only obvious advantage I can see is that it allows for a larger primary reflector in a given head size.
Here’s my review of the Imalent MR90
And here it is next to some other Imalent flashlights
The flood and spot combo is really cool on this light. You can switch between flood, spot or both at any brightness level.
Nice review, thanks.
If the power pack fails,is it possible to fix it?
