Looking for a driver for 24V input
Hi,
I want to build a work light, which is powered from a power drill battery (24V) As a light source, I would like to use a Luxeon V, because I still have on here. The driver should be able to deliver up to 3A and also come with lower power modes. I dont need anything that does battery protection, as this is done inside the battery itself. Does anyone have a recommendation? Size doesnt really matter, as I will be 3d printing a case for the electronics. It should have a high efficiency, as I dont want to have to actively cool the driver.
https://www.aliexpress.com/item/32897204926.html?spm=a2g0o.detail.0.0.5f53e479lZUEfI&gps-id=pcDetailCartBuyAlsoBuy&scm=1007.33682.207861.0&scm_id=1007.33682.207861.0&scm-url=1007.33682.207861.0&pvid=f71cdc35-8c59-4d37-843b-f939ed68f2a6&\_t=gps-id:pcDetailCartBuyAlsoBuy,scm-url:1007.33682.207861.0,pvid:f71cdc35-8c59-4d37-843b-f939ed68f2a6,tpp_buckets:668%232846%238107%231934&pdp_ext_f={"sku_id"%3A"65779862348"%2C"sceneId"%3A"2908"}&pdp_npi=2%40dis!EUR!!0.95!!!!!%402101d1af16521064825236183e311b!65779862348!rec
This doesnt really do 3 Amps, does it?
Or you get dc dc converter to 5V and use ordinary flashlight driver or use it directly . Kind of https://www.aliexpress.com/item/32860203965.html?spm=a2g0o.detail.1000060.3.560422c8OIIXGz&gps-id=pcDetailBottomMoreThisSeller&scm=1007.13339.274681.0&scm_id=1007.13339.274681.0&scm-url=1007.13339.274681.0&pvid=0c73eecb-dcec-426a-bd3f-0af57602f60a&\_t=gps-id:pcDetailBottomMoreThisSeller,scm-url:1007.13339.274681.0,pvid:0c73eecb-dcec-426a-bd3f-0af57602f60a,tpp_buckets:668%232846%238110%231995&pdp_ext_f={"sku_id"%3A"65336038802"%2C"sceneId"%3A"3339"}&pdp_npi=2%40dis!EUR!!1.46!!!!!%402103222716521107437863744e539d!65336038802!rec
https://www.aliexpress.com/item/1005003803756109.html?spm=a2g0o.productlist.0.0.37ac5f9fHvaBmn&algo_pvid=11cdd856-9cc0-4591-87e6-37095db27d05&algo_exp_id=11cdd856-9cc0-4591-87e6-37095db27d05-52&pdp_ext_f={"sku_id"%3A"12000027221288437"}&pdp_npi=2%40dis!EUR!!3.64!!!!!%402101fd4b16521108976852903e438b!12000027221288437!sea
There are plenty of adjustable CC-CV buck converters on Aliexpress, get a 5 or 10A for safety margin.
