I wonder if Sofirn could be convinced to make the BLF version 26800 compatible… it’s just a longer tube, right?
Interested.
Definitely interested! Personal preference being as close to 4000k as possible.
Sort of interested.
Would prefer the GT-FC60 in the Convoy M3-C as it regulates at a constant brightness instead of Sofirn’s rollercoaster heat management, but I think I could be convinced.
Is there an estimate of max and sustained brightness in the SP33S?
In
Interested in this LED for sure… Hopefully soon, more details about the light will be out since Sofirn is on the move…
If we could get the firmware/controller chip swapped out for an Anduril one we would have much better thermal management, it would be nice if that could be done too.
Interested.
Interested but not 100% convinced, probably intrigued enough to gamble on it though.
Interested.
slmjim
Interested
Interested
Also interested
very interested.
anduril 2 please.
I’m interested as well if this can happen.
Seems very interesting but I would have liked an host that uses 21700. I know I can use a 21700 with a sleeve but it’s still too big for EDC’ing.
Interested
In
Yes Please!
You’ve all been added.
Now let’s address some concerns:
- Why not Anduril 2 for this light?
Well for one, Anduril is a nice UI, but even in its simple mode, it can be daunting to use.
Practicality wise, this would require a driver redesign, and we mainly wanted it to be a direct LED swap for now as to make it as simple as just swapping the LED
This was done specifically as ground zero for this new LED, and making it an inexpensive investment in a light that is already quite good overall.
If the light is very popular with the LED, I might consider asking Sofirn to put Anduril 2 on the light.
- Why not a 21700 light instead of 26650?
Believe me, I’d have preferred a 21700 light myself, but since the other light with a capable boost driver uses a 5050 LED, that makes the swap to a 7070 LED a bit more difficult.
Now, the Sofirn C8L is the next candidate for such a swap, but that’ll come later since it would need a reflector swap
