Would prefer the GT-FC60 in the Convoy M3-C as it regulates at a constant brightness instead of Sofirn’s rollercoaster heat management, but I think I could be convinced.
Is there an estimate of max and sustained brightness in the SP33S?
If we could get the firmware/controller chip swapped out for an Anduril one we would have much better thermal management, it would be nice if that could be done too.
Well for one, Anduril is a nice UI, but even in its simple mode, it can be daunting to use.
Practicality wise, this would require a driver redesign, and we mainly wanted it to be a direct LED swap for now as to make it as simple as just swapping the LED
This was done specifically as ground zero for this new LED, and making it an inexpensive investment in a light that is already quite good overall.
If the light is very popular with the LED, I might consider asking Sofirn to put Anduril 2 on the light.
- Why not a 21700 light instead of 26650?
Believe me, I’d have preferred a 21700 light myself, but since the other light with a capable boost driver uses a 5050 LED, that makes the swap to a 7070 LED a bit more difficult.
Now, the Sofirn C8L is the next candidate for such a swap, but that’ll come later since it would need a reflector swap
I was actually thinking of this host to put the FC60 sample in, and making a QFN16-T1616 to TSSOP14-PIC16F1856 adapter to convert the driver to anduril, might be possible but it depends on the layout of the ot MCU. Indeed it would be nice if Sofirn could made an Anduril edition, especially since the thermal regulation appears to be wonky on this model.
Edit :
(Picture courtesy of Haukkeli)
There shouldn’t be many changes needed for Sofirn to make it anduril compatible (T1616), lots of space for a different trace layout on the daughter board, then it would just need an additional connection to the main board for the programing pad.
I came here to say exactly this. I’m interested if it has Anduril 2. An optional 26800 extension and some flashing pads in Hank’s or Lexel’s layout would be excellent as well, but not deal breakers.
@thefreeman, you’ll also have to do some driver resistor modifications though, since the FC60 samples could only be made in 12V because of low qty sample manufacturing as noted in the thread.
