I’ve actually found another manufacturer making a high CRI 5050 3V LED!!!
Even better from Rayten in some ways: single emitter die(so it should have higher intensity and no cross-die), Ra9580 (not a “puny” R9070) and a nicely lower VF for better regulation
The only downside? Much higher thermal resistance(5C/W instead of 2C/W) and a bit lower efficiency.
5C°/W is not very good, especially for a 5050 LED, that’s 219C level of thermal resistance (4.2~6.4), first gen XM-L2 is 2.5, new gen 0.75, SST-40 : 0.8
Datasheet does look a little suspect but if any of that is to be believed then these look like fragile dim emitters. 900 lumens at 3amps on a 5050? Reflow info doesn’t make them seem very robust…maybe the info taken altogether suggests that they wouldn’t be very good in a flashlight host where things are cramped and hot.
Still waiting to hear back again from my Luminus fellow on whether high CRI and/or lower temps are in the cards for those emitters but if so we’re looking at probably more than a year away. (I wonder if, say, Hank and Simon and Sofirn were to get together and request several reels if Luminus would make a special run……the dream team collaboration. lol)
My impression is with companies like Nichia and Luminus you have to be regularly ordering hundreds of thousands of high power LEDs before any kind of customization would be on the table. Nichia won’t even sell their low yield special chromaticity bins to regular customers ordering in the tens of thousands.
It’s not a very high res picture, but measuring it in CAD shows between 1.35mm sq and 1.8mm sq, depending on whether it is measured from the fuzzy part of the outline of the phosphor or the more solid part.
