code for IF22A:SDHQJWARHRHS
I have a question regarding the HS10. The product description states that it takes 5V/1A for charging. But the Sofirn 16340 batteries sold are rated to max 750 mA cont charging current. So I’m worried that the provided battery is charged with a too high current. Could you please clarify the current used for charging?
Hi checked with our engineer, charging works
SP33S $36 after code :39QZ2ZUO3ITS
Hi Jackie! Are any more codes for Sofirn HS10 still available? Thanks, appreciate you!
$4 off for HS10 --1F6C1SL44SO4
Thanks, ordered 2700K version. Do you know, will the SC21 Pro mini come with 2700K in the future?
yes, i think so , like SC21 ,will have 2700/4000/5000
Hi Jackie
Can you comment on the release of the upcoming SC32?
Thank you.
SP10 PRO $3 coupon-M9NUCPJUMOLX
i update a link here of SC32, the shortest 18650 EDC light with USB-C Port, electronic tail switch, 10cm length:
Thank you.
I ordered one.
HS10 $15.8 with 2700k/4000k/5000k in stock after code —SFHS105
SP36 PRO 8000lm anduril 2.0 $36.89 limited deal now
Hi Jackie,
The HS10 code is not working, can I please have a new one?
Thank you
new code update —ODXM7V1W1HXN
work for sofirn HS10 ($15.53 after code)
sofirn LT1 mini ($36.99 after code)
sofirn SC32 ($25.86 after code)
Jackie which is the code for the LT1M? ODXM7V1W1HXN does not work
Jackie:new code update --ODXM7V1W1HXNwork for sofirn HS10 ($15.53 after code)sofirn LT1 mini ($36.99 after code)sofirn SC32 ($25.86 after code)Jackie which is the code for the LT1M? ODXM7V1W1HXN does not work
sorry, the correct code is :P38DXWMHHJFB
Hi Jackie
Are there special codes for Europe (Switzerland)?
P38DXWMHHJFB, V3RPAUBLLBS6, WUXY0MNU80Q7, they don't work here at the moment...
Thanks!
