It’s not a very high res picture, but measuring it in CAD shows between 1.35mm sq and 1.8mm sq, depending on whether it is measured from the fuzzy part of the outline of the phosphor or the more solid part.
Slurp
The manufacturer and our contact is really dedicated, god damn
They don’t know the LES of their own LED so you have to ask high res pictures to estimate it ? Lol
I got this using webplotdigitizer : 1.53x1.17 = 1.79mm2
SST-20 is 2mm2 I think ? so it’s quite similar, no dome, but probably lower current handling as SST-20 thermal resistance is 1.6C/W
That’s something that’s really strange about a lot of manufacturers that I’ve dealt with outside of Getiand and Rayten.
LES stuff doesn’t seem to be something they put in the datasheets lmao.
How come they can’t give me every detail possible about the physical parameters of the LED?
Anyway, with the amount of money I would need to invest to and the rather high thermal resistance, I’m not sure we should go with this LED, even though it looks a lot more… interesting than the Rayten LED (Ra9580 and much smaller single LES).
With the new picture I get 1.95mm sq.
So 2mm2. About as small as the SST-20, but domeless.
If only it had much lower thermal resistance and was cheaper, because as it stands, this one costs a lot more than 2$US, even in bulk lmao.
So, fogofwar will test the LED next week:
“Ah I haven’t had time this week. I’ll try next week”
I’m patient, but hopeful
Anyway, I have an idea about the other LED. We won’t be doing a group buy for it, but after the Rayten GB ends, I think we’ll be able to do something else
Holy...from XHP50 gen1 design to super CRi thrower...WOW
Yeah, but I’m not going to get this one, especially not for the GB.
It would increase prices considerably
Ahh ok... I guess i had to read all previous posts before posting LOOOL
You misinterpreted me a bit. I just contacted the guy and will get samples shipped to me next week. I’m quite slow so it’s probably at least another week or two before any test results. Right now, I don’t have any extra MCPCBs, drivers, or hosts so I need to get those as well.
Oh OK OK.
I misunderstood
I think the lumens are rated at 1A.
Great work Bluesword, can’t believe you’re actually getting an LED built.
I’ll buy 10 just as a token to support what you’re doing.
@Marc E, thank you.
@fogofwar, very nice.
Is it an impression or do the dies look way closer than in the datasheet?
I’m not sure on closer but the cross does have phosphor which should help.
Nice. Think you could take some high quality close up shots? That would be great, thank you
All the remaining peeps have been added.
I’ll take 30 pcs.
