Hi checked with our engineer, charging works
SP33S $36 after code :39QZ2ZUO3ITS
Hi Jackie! Are any more codes for Sofirn HS10 still available? Thanks, appreciate you!
$4 off for HS10 --1F6C1SL44SO4
Thanks, ordered 2700K version. Do you know, will the SC21 Pro mini come with 2700K in the future?
yes, i think so , like SC21 ,will have 2700/4000/5000
Hi Jackie
Can you comment on the release of the upcoming SC32?
Thank you.
SP10 PRO $3 coupon-M9NUCPJUMOLX
i update a link here of SC32, the shortest 18650 EDC light with USB-C Port, electronic tail switch, 10cm length:
Thank you.
I ordered one.
HS10 $15.8 with 2700k/4000k/5000k in stock after code —SFHS105
SP36 PRO 8000lm anduril 2.0 $36.89 limited deal now
Hi Jackie,
The HS10 code is not working, can I please have a new one?
Thank you
new code update —ODXM7V1W1HXN
work for sofirn HS10 ($15.53 after code)
sofirn LT1 mini ($36.99 after code)
sofirn SC32 ($25.86 after code)
Jackie which is the code for the LT1M? ODXM7V1W1HXN does not work
Jackie:new code update --ODXM7V1W1HXNwork for sofirn HS10 ($15.53 after code)sofirn LT1 mini ($36.99 after code)sofirn SC32 ($25.86 after code)Jackie which is the code for the LT1M? ODXM7V1W1HXN does not work
sorry, the correct code is :P38DXWMHHJFB
Hi Jackie
Are there special codes for Europe (Switzerland)?
P38DXWMHHJFB, V3RPAUBLLBS6, WUXY0MNU80Q7, they don't work here at the moment...
Thanks!
Hi Jackie
P38DXWMHHJFB, V3RPAUBLLBS6, WUXY0MNU80Q7, they don’t work here at the moment…
Thanks!
The codes might not work until the 27th sale?
When will the Sofirn SC32 with SFT40 LED be available for purchase? (It is grayed out at this time)
