Twenty five years ago I bought a lined Italian milsurp cold-weather parka for $27.00. Fugly styling & trendy Olive Drab, with a removable hood that's large enough to generously cover a combat helmet, but the parka is warm enough in 0 deg. F. winter weather to keep me reasonably comfortable while on my daily one-mile-walk dog park excursions. At 40 deg. F. it becomes too warm unless unzipped. Best $27.00 I ever spent. The past few years, the zipper has been acting up & I've been looking for a replacement.
One of these ski jackets might fill the bill.
Sizing is the big unknown. Wife & I spent the better part of a half hour with a tape measure trying to figure out what sizes to buy. The size charts posted for all the similar brands seem not to be related at all to actual human body proportions. Lots of questions in feedback on sizing too that weren't very helpful either. We each ordered one, based on best-guess hunches. Interestingly & much to my surprise, she chose a pink camo jacket (after 30+ yrs. of honeymooning, seems she still has a surprise or two in store for me). Dog
At 80% off on both, they each came to just under $17.00 shipped.
If they don't fit, they'll be inexpensive donations to Goodwill or homeless shelters. Doubt they'll be as durable as my trusty old milsurp parka, but we're old enough now that if they only last 10 or 15 yrs, we may not be around to care.
So, I have had some time to play with my new TS21 and have a few observations that might be of interest. I am thinking there are 3 versions, the Anduril 1, Anduril 2 without power bank and Anduril 2 with power bank.
Mine appears to be the transition Anduril 2 model, my documentation does not mention power banking and I am trying to think of a way to test the feature that will not damage the driver if I am wrong. I still have not figured out the switch light, I am able to change it from off to dim to bright and blinking bright. It does react when going from regulated to direct drive. Mine draws 8.5 amps in turbo with the included 5000mAh cell with a Samsung 50E the light pulls 9.8 amps. I lost the 4000k tint lottery, lots of green and it is glued up pretty well. I am seeing .012~ amps in standby. I am also a little bummed that 3C from locked does not unlock to off and that there are no flashing pads.
I really do like the light, while large it still carries well. I EDC’ed it all weekend and it was a good jeans front pocket fit! The ribbed body really makes if feel like a large Zebralight, overall I am pretty happy with the light.
You have to do the 10H to toggle over to the advanced UI. Default is simple UI.
Mine has a glitch where when I ramp up to max, not turbo, the light shuts off. It happened three times, typically after I unscrewed/tightened the tail cap. It didn't happen after that in further testing. At least, so far today. I'll keep testing it.
My TS21 will arrive today. Hope I’m up to programming out these inherent glitches. I have other lights with Anduril but have never ventured beyond the basic UI.
I can’t figure out the light for the switch either. I thought it would indicate charge level when turned on. First, mine is blue not green. It seems to come on randomly. At times it seems to glow weakly amber. Even thought the cell if fully charged. I haven’t run the cell down to see if it actually will change with power level. It does flash blue when charging and goes on steadily when fully charged. Fortunately, everything else works as it is supposed to. Though I don’t know how to check the power bank function without risk…
Overall it is a nice light, especially at ~$26 including a decent battery.
It is about a half inch shorter than my S21B, but bigger in diameter and heavier. Maybe just a bit too large for EDC pocket use.
It is just not very bright considering it’s specs. But tint is pretty good on mine.
I would still call it a “BUY” if the deal is still good. I don’t think I would go for it at full price. But I just have too many similar lights to make it something I need.
The switch light does not indicate charge level,that is 3 clicks from off and it will count out the battery voltage. The light has a known quirk where the switch will do random flashes.
Get out your 10X magnifier — Wow the writing is small in the manual — I found a Anduril 2 diagram on BLF — Nice light —Same old crap as the FW3 — when it gets hot it continues to step down
What would you prefer as an alternative? Alternative would be to get the light so hot that you would not be able to touch it or to have the light so big that it would not be practical as an EDC.
Yep, continual stepdown, or at least my FW3A does.
I have grown to once again prefer modes, if it gets to hot I “step it down” manually or wear thicker gloves.
I don’t mind the light stepping down — I do mind it continuing to step down to 200- 250 lumens then ramp back up —- I have verified the FW3 does this (Light Tube) even when I set the top of the ramp to 700 lumens — They do this little dance from 700 lumens down to 200 lumens then slowly work their way back up to around 600 lumens
I’m not sure if the Wurkkos does this, but I will be checking it further — I know I had it outside for a very short time and it was continuing to step down
