You have to do the 10H to toggle over to the advanced UI. Default is simple UI.
Mine has a glitch where when I ramp up to max, not turbo, the light shuts off. It happened three times, typically after I unscrewed/tightened the tail cap. It didn't happen after that in further testing. At least, so far today. I'll keep testing it.
My TS21 will arrive today. Hope I’m up to programming out these inherent glitches. I have other lights with Anduril but have never ventured beyond the basic UI.
I can’t figure out the light for the switch either. I thought it would indicate charge level when turned on. First, mine is blue not green. It seems to come on randomly. At times it seems to glow weakly amber. Even thought the cell if fully charged. I haven’t run the cell down to see if it actually will change with power level. It does flash blue when charging and goes on steadily when fully charged. Fortunately, everything else works as it is supposed to. Though I don’t know how to check the power bank function without risk…
Overall it is a nice light, especially at ~$26 including a decent battery.
It is about a half inch shorter than my S21B, but bigger in diameter and heavier. Maybe just a bit too large for EDC pocket use.
It is just not very bright considering it’s specs. But tint is pretty good on mine.
I would still call it a “BUY” if the deal is still good. I don’t think I would go for it at full price. But I just have too many similar lights to make it something I need.
The switch light does not indicate charge level,that is 3 clicks from off and it will count out the battery voltage. The light has a known quirk where the switch will do random flashes.
Get out your 10X magnifier — Wow the writing is small in the manual — I found a Anduril 2 diagram on BLF — Nice light —Same old crap as the FW3 — when it gets hot it continues to step down
What would you prefer as an alternative? Alternative would be to get the light so hot that you would not be able to touch it or to have the light so big that it would not be practical as an EDC.
Yep, continual stepdown, or at least my FW3A does.
I have grown to once again prefer modes, if it gets to hot I “step it down” manually or wear thicker gloves.
I don’t mind the light stepping down — I do mind it continuing to step down to 200- 250 lumens then ramp back up —- I have verified the FW3 does this (Light Tube) even when I set the top of the ramp to 700 lumens — They do this little dance from 700 lumens down to 200 lumens then slowly work their way back up to around 600 lumens
I’m not sure if the Wurkkos does this, but I will be checking it further — I know I had it outside for a very short time and it was continuing to step down
