Thanks, Rick! I couldn’t believe just how well cloned your KE-5 and the 950L were. Even the machining marks looked identical. Only the ano color was different.
Did you see my other posts about the UF 980L (daddy of all these clones!) being only $21 right now at Tmart? Wish I had seen that before getting this! It’s a good light and all but for even less you can get what appears to be the original legend.
I think i should make Tmart’s coupon more showy to meet someone’s need, So i update it here.
Mind you that Beamtech BT-950L is in stock both in US & HK warehouse.
Keygos also started to ship lights with such reflectors and Im not satisfied with it.
Reflectors in original KE5s were maybe the best thing in whole flashlight. Slightly elongated, not very curved (more flat), it made for a very good throw.
Now KE5s come (you cant be sure which one youll get) with different reflector, more similar to C8 reflector, more curved, so less throw
SO, in short, recently I received Keygos with exactly the same reflector as here, and Im not satisfied with it because I was used to great reflector on first KE5s.
Its so unfortunate Chinese suppliers change things just like this.
Its still a good flashlight, but it was a hell of a XML thrower before, with that different reflector…
And I think this Beamtech is pretty the same flashlight (maybe 100%) just branded differently,a s last KE5s, so I dont see a need to pay few bucks more for the same flashlight, just branded differently.
PS: Also, KE5 had problem with drivers, as far as I know, only for a short tim and it was corrected. All lights in last severalmonths, from different ebay sellers, came with good drivers.
PPS: And to correct the reviewer, Keygos sells at cca 21$, thats lowest price. So this is pretty the same flashlight, just worser version (good driver, but not good reflector like before…) same as Keygos, more expensive, and my reccomendation, buy it if you like Beamtech brand very much
To confirm that: I’ve just received last batch of KE5s from ebay (Redlog store), and flashlight is 100% indentical to Beamtech from this review.
Unfortunately, I might add, for me, because I liked old KE5 version much better…
Flashlight was paid $20,51
Its still great flashlight, it has same hotspot as Ultrafire HD2010 for example (I expected tighter hotspot from that wide reflector…)
But HD has nicer tint.
All in all, old KE5 was unbeateble, it had tighter hotspot, great XML thrower for such small, lightweight flashlight.
Ill ask Keygos where can I get old version…
Just had a look on eBay, redlogs doing the ke-5 for 13 quid, the bt-950 is more expensive BUT seems the proper driver is gaurantee’d, I would say from this review…. Just nearly pulled the trigger, please talk me out of it, the beer is not helping…. Upshot, I don’t have o-rings to sort it out, downside, I have a c8 so gitd o-rings would be useful……
Er, no, $20aus appears to equal £13 or 13 quid :bigsmile: and its still not helping, the bt-950 is £17.88 according to tmart, I must just be getting a good exchange rate. :cowboy_hat_face: which is not helping……
Pretty much the same except this is an 092b where the one at FastTech is just 092. I’m not sure what the difference is but someone else could perhaps answer that one.
Can someone please link me to this 092B driver being sold on fasttech? I cannot seem to find it. Ifoumd the 092 on fasttech but it seems to be regulated and max 2.4.
