Fenix GL19R 1200LM 6500K Tactical LED Flashlight w/ARB-L18-1100P Battery
Authentic / Luminus SFT40 emitter / 3-mode / USB-C charging / IP68 / 210m throw / 11000cd
Details:
We’ve engineered the Fenix GL19R specifically for you to enhance visibility and targeting capability in shooting activities. GL19R is extremely compact and virtually indestructible, delivering intense white light up to 1200 lumens and 210 meters of powerful beam distance. It can attach securely to both Universal and Picatinny accessory rails rapidly with a patented QD lever. The ambidextrous rear switches provide instant one-finger control of momentary-on or constant-on activation. The strobe mode can be activated through long-pressing with the light on to help you control the situation.
Features:
1200 lumens maximum output, 210 meters maximum beam distance.
A Luminus SFT40 LED with a lifespan of 50,000 hours.
Included a ARB-L18-1100P rechargeable Li-ion battery.
Design for guns with both GLOCK universal rail and Picatinny rail.
QD lever for quick install and quick detach.
Instant strobe.
Ambidextrous switching with dual tactical tail switch.
USB Type C charging port.
Made of durable A6061-T6 aluminum.
Premium type HAIII hard-anodized anti-abrasive finish.
Intelligent circuit protection, high-performance battery.
IP68 rated protection: GL19R is deemed tough enough to withstand dust, dirt and sand. It is sealed for weatherproofing, resistant to submersion up to a maximum depth of 2m underwater for up to thirty minutes.
When mounting the GL19R, make sure the firearm is unloaded, and adjust the rail clamp bolt to obtain sufficient tightness.
The GL19R can fit most Surefire X300U holsters.
1m impact resistance
3.0V-4.2V working voltage
