Hi, guys!
Thank you for your active participation. The list of winners we got through the random.org website is as follows:
*1,#91 ohbreeeezy
2,#69 wilkins1kc
3,#24 korpzgrinda*
Congratulations! Please PM us to send your recipient information including name, address, phone number, etc. We will send the prize as soon as possible.
Thank you, everyone. Have a nice day!
I think you will be very interested in this product. It is a practical headlamp named HS5R. The features of this headlamp are as follows, hope you will like it.
1 * LUMINUS SFT40 cold white LED, 2 * red LEDs with 50,000 hours of lifespan.
1 * 18650 and compatible with 2*CR123A batteries.
Intelligent IC controls temperature.
Mode memory function.
Electronic anti-reverse connection design, compatible with flat batteries.
Red and white dual light source to meet the needs of multi-scene lighting.
Button lock protection function.
Battery level and charging indication function.
Made of A6061-T6 aircraft-grade hard aluminum alloy.
Ultra-thin lens.
Magnetic suction tail cap.
All-metal design.
Can be used as a flashlight.
TYPE-C high current charging.
Maximum brightness output 1300 lumens & 200 meters.
IPX8 waterproof level, 2 meters impact resistance.
Spotlight & floodlight.
Workable temperature: –30℃ to 50℃.
Weight: headlamp 47g; headlamp(including battery) 94g; headlamp(including battery) with accessories (headband, bracket) 135g.
Dimension: 92mm (length) * 23mm (height) * 28mm (width).
_
Hi, guys!
We will have a new headlamp released in Jun.
Equipped with an SFT 40 LED, it is a high brightness multi-light headlamp designed for outdoor sports, industrial work, repair, and camping. Lightweight metal shell, IPX8 waterproof protection level, ultra-thin lens. support TYPE-C charging. Wider headlamp strap to wear more stability. It can meet your lighting needs in different environments.
【Giveaways】
What does it look like? How many lumens does it output? What is its UI interface like? What kind of battery does it have and how does it last? You may be curious about it, leave your comments. We will randomly draw 3 lucky winners in the comments section to win our newest headlamp!
Rules:
Rules:
A. Post a comment on ’Cyansky 2022’or share your thoughts on this new headlamp.
B. You have to be A BLF member before 1st Jan. 2022.
C. Your post number is your lucky number.
D. Each account has one chance.
E. 3 Winners picked by random.org on 31th May (GMT+8).
You may be the first lucky guy to own the Cyansky newest headlamp. Good luck.
