I hate heavy headlamps so it is a good move by you Cyansky to go with a light weight headlamp.
Thanks for the GAW!
Thanks for the GAW!
L shaped would be best! Thanks
Cyansky is developing some really nice products. I really hope this headlight is floody and has an high CRI led.
New Cyansky headlamp!? Sounds interesting. I like a lightweight single strap headlamp.
Thanks for GAW.
SFT40 is an interesting emitter choice. It should provide good throw. Do you have any photos of this new model?
Looks good to me
I would like it to be detachable from the headband and have a magnetic tail cap as well as a 21700 battery for more range.
I have the HS6R and it’s about perfect. I prefer t-shape headlamps. Probably has a high cri floddy emitter. If you swapped the sst40 for the SFT40-W and change the optic a bit (or left it alone), that would be awesome. Maybe inside a higher capacity battery 3100 mah? Keep it 18650 for lightweight though. Output? 1500 lumens for the SFT40-W and 800 for the high cri emitter.
Eh, the SFT-40 LED wouldn’t be my first choice.
L-shape with a 21700 would be something I’d be interested in.
Looks good!
headlamp with USB-C charging sounds great; the smaller and lighter, the better
Please make it a 16340 format, single emitter, obviously side switch, powerbank feature (may seem useless with the batttery format, but you never know) and as light as possible!
The SFT-40 is one of my new favorite LEDs! A headlamp with it and usb c should be awesome!
Thanks for introducing another headlamp, and for the GAW, Cyansky. My most-used type of light, can never have too many!
The USB charging is very useful. Thanks for the chance!
Wider more stable strap is a good feature.
red emiter
interested! sounds like it will work great for outdoor night hikes
I’m looking forward to seeing all of its specs; I have one throwy headlamp now, but without aux lights, so I’m still looking for another.
