I would like it to be detachable from the headband and have a magnetic tail cap as well as a 21700 battery for more range.
I have the HS6R and it’s about perfect. I prefer t-shape headlamps. Probably has a high cri floddy emitter. If you swapped the sst40 for the SFT40-W and change the optic a bit (or left it alone), that would be awesome. Maybe inside a higher capacity battery 3100 mah? Keep it 18650 for lightweight though. Output? 1500 lumens for the SFT40-W and 800 for the high cri emitter.
Eh, the SFT-40 LED wouldn’t be my first choice.
L-shape with a 21700 would be something I’d be interested in.
Looks good!
headlamp with USB-C charging sounds great; the smaller and lighter, the better
Please make it a 16340 format, single emitter, obviously side switch, powerbank feature (may seem useless with the batttery format, but you never know) and as light as possible!
The SFT-40 is one of my new favorite LEDs! A headlamp with it and usb c should be awesome!
Thanks for introducing another headlamp, and for the GAW, Cyansky. My most-used type of light, can never have too many!
The USB charging is very useful. Thanks for the chance!
Wider more stable strap is a good feature.
red emiter
interested! sounds like it will work great for outdoor night hikes
I’m looking forward to seeing all of its specs; I have one throwy headlamp now, but without aux lights, so I’m still looking for another.
What are the lumens for the lower settings?
Thanks for the giveaway, Cyanskyflashlight!
The SFT-40 is my favorite emitter right now.
If the headlight is powered by one 18650 or one unprotected 21700, please count me in.
Maybe a TIR lens?
Nice job on picking the SFT-40. One issue I have with headlamps is the weight and comfort, so hopefully you find a good balance.
Thanks for the giveaway, CYANSKY. Count me in.
If this new headlamp is going to be similar to the HS6R headlamp, but with an SFT-40 emitter, it should be a winner.
Hope I am, too!
Is it going to be a flooder or thrower? Or both?
