This is what I've ordered, it doesn't say out of stock, but perhaps there will be a delay. For single emitters, I haven't seen anything:
https://www.aliexpress.com/item/3256803779657337.html?spm=a2g0o.cart.0.0.6bfc3c00Nxlsk0&mp=1
Is that an L8 driver?
Its 4x18a driver
FYI, I just received eight new C8 glass lenses and all of them have the pink AR coat. If you are purchasing these individually, don’t expect them to have the new green AR coat.
If anyone in the USA needs these, PM me. I will send them to you for free.
Very generous of you Rayoui!
BlueSwordM:Also, last I checked, the FC40 Convoy uses is R9080, so the color rendering isn’t really worse or better than the B35AM.
Convoy advertises R9080 for FC40 currently
uh,FC40 R9050 ,not R9080
Simon, any updates on when we will be able to order the 519A’s? I’m super anxious waiting for it already.
Sorry, I also keep urging and hope to receive all 519As soon
Simon, I’m wanting to build a small 450nm royal blue light and I think the T3 host and driver (complete light of course) will be perfect. Does the T3 use the same cut shape mcpcb as the T2? If so, could I buy a couple of spare mcpcb from you on that order?
lg.tech:Simon, any updates on when we will be able to order the 519A’s? I’m super anxious waiting for it already.
Thank you for the update Simon!
Oh, the FC40 inside of Convoy lights is “only” R9050.
That does put sort of a different spin, interesting.
Maukka tested an early sample here (very green and R9 goes down to 42 on high)
Edit : zeroair tested a production sample here (much less green and higher R9, 76 kn high and above 80 in other modes)
yes, the same
if you just need 2pcs ,pls note “add 2pcs MCPCB for T3 ” in the remarks.
i will add 2pcs for free
Correllux:Simon, I’m wanting to build a small 450nm royal blue light and I think the T3 host and driver (complete light of course) will be perfect. Does the T3 use the same cut shape mcpcb as the T2? If so, could I buy a couple of spare mcpcb from you on that order?
yes, the same
Thank you, sir!
2022/5/24
519A 5700K 5000K 4500K 4000K 3500K 3000K available now
2700K will be available in one week
Long waited, and yes, we have it now… :+1:
2022/5/24
2022/5/24
Wonderful news, I’ve just put my order in and left a note for you!
Thank you!
How do the smXX5 bins compare with the smXX3 for the 519a? Do most of the neutral ones get picked out to fill the smXX3 bins, leaving mostly “extreme” green and red ones in the smXX5?
From the 5 samples I had there wasn’t much difference regarding duv, for the CCT they were a bit warmer :
2022/5/24
Excellent news. Will put in an order when 2700k arrives!
