Thanks for the info.
How do you like it? I’ve read that the high CRI options are nice but underwhelming. People expect a hot rod since it’s a Hank light. Something reasonable is not an option
I believe that he said that they don’t fit.
Same here, I dont think to have 1 more part for charging only is a good idea
The light it puts out is great, very natural. But if you are looking for max lumens, it is lacking there. A couple of weeks ago I got another DT8 with the Osram W2’s. This one is much brighter. I think with the SST’s, the DT8 puts out around 4000 lumens and with the W2’s around 6000.
I have to make a new ring for the Lumen Tube I just got from TexasAce and then I can get real numbers.
Hikelite:The thread count on the D4v2 head is simply too small for that.
One more piece causes one more anodizing nuance mismatching, not a good thing at all.Same here, I dont think to have 1 more part for charging only is a good idea
That’s precisely why it’s a separate part. You can choose not to buy it and have your port-less light that you want, while others can choose to buy it and have a charging port.
norve: Hikelite:The thread count on the D4v2 head is simply too small for that.
I like this option.
It could be selectable… Like magnetic tailcaps, check here if you want a USB charging tube, check here if you want an extra non-USB tube.
519A 5700K, 4500K, 3500K are available
Great news Hank! Do you know if they are 5 stage or 4 stage? And if they are L5 or L6?
Great news! Will 2700K and 3000K be available soon?
Same question as above. I wanted a 2700/4500K mix.
Great, but AVAST is detecting something on the site .
It’s probably Avast’s fault TBH.
No trackers, no ads, no nothing on the Emisar website.
This kind of thing comes up on occasion because the heuristics these programs use don’t like something about Hank’s web hosting. It’s a false alarm.
Does anyone know the maximum lumen outputs of the 519A 3500K domed and dedomed, or where I can find the info? It is not mentioned under the D4W specs.
Hi Hank,
Will there be an option for 519A in the DM11 and KR1?
Thanks.
Hi Hank,
Thanks.
+1
If there is enough interest will 519a 2700k be available in the future?
I think Hank has ordered 2700k, they just haven’t arrived yet.
How much output should one expect from 4x 519a paired with the boost driver?
Around 1,800?
carsknivesbeer:If there is enough interest will 519a 2700k be available in the future?
I saw an email from Hank stating 2700k would be in next week.
