FastTech New Arrivals & Promotion
Lumintop Thor 3 400LM EDC LEP Flashlight w/21700 Battery
white laser emitter / 2-mode / 1*21700/1*18650 / IPX8 / 2500m throw / 1562500cd
Details:
Temperature control protection: When the temperature of the flashlight exceeds 50 degrees, it will automatically downshift, and the brightness can be manually adjusted after downshifting.
When using 18650 Li-ion batteries, an 18650 conversion tube is required (not including 18650 battery and conversion tube).
Supports one pointed 21700 lithium battery with protective plate.
Waterproof: IPX8 (submersible to 2m for 30 minutes).
Switch: Rear E-switch with RGB light.
Impact resistance: 1m
Head diameter: 59.3mm
Tube diameter: 25.4mm
Check Out The Best Sellers Of May - Up To 35% Off
Coupon Code: DEALS
Ends on: June 20th
Lumintop Ant Man Aluminum Alloy 165LM EDC LEP Flashlight
white laser emitter / 1-mode / 1*14500 / IPX8 / 590m throw / 87025cd
Lumintop Ant Man Stone Washing / SandblastingTitanium Alloy 300LM EDC LEP Flashlight
white laser emitter / 3-mode / 1*14500 / IPX8 / 700m throw / 122600cd
Details:
Waterproof: IPX8 (submersible to 2m)
Head diameter: 22mm
Tube diameter: 19/20mm
Please note:
The intensity of the flashlight is extremely high, and it is strictly forbidden to shine directly into the eyes.
Keep away from children.
Fasttech - Any discount on fenix Ld22 v2?
Convoy sells O-ring , they work really well. I use them for 21700 in my astrolux ft03. And before on mf01 mini.
Fasttech- Does this “Best Seller” XOSS G+ come with the accessories to mount to bicycle, charge battery , and the wheel sensors?
Got link?
ArtieT59, the price of fenix Ld22 v2 is $56.93. We will have a site-wide anniversary celebration on June 15th. You can get the discount at that time. Thank you.
Paul321, XOSS G+ has the rubber gasket, bile computer mount, rubber band, USB cable with it. We will add the details to the Specifications and upload a picture.
Gravity Sensor Stepless Dimming 24*2835 SMD LED Night Light Table Lamp
Details:
Features:
Adopt SMD2835 high-efficiency chips, high brightness, low power consumption, low light decay, no flicker, soft light, energy-saving, and environmental, more than 85% energy saving than traditional halogen lamps.
Built-in gravity sensor, first turn on the light by touching the switch, tilt to the side with the touch switch, and the light turns on. tilt to the other side without the touch switch, the light turns off, and repeated operations will keep turning the light on/off repeatedly.
The unique appearance design and the seesaw-shaped lamp body design make gravity sensing operation more simple and convenient.
Multiple power supply methods. Built-in 400mAh battery, when the battery runs out, you can plug the USB cable into various USB device interfaces such as computer, power bank, USB adapter, etc. for charging, which is very convenient and practical (We give away 1 meter USB cable).
There is a touch switch on the lamp, long press can stepless dimming, and adjust the desired brightness according to actual needs.
Using ABS shell material, efficient heat dissipation, improves heat dissipation efficiency, effectively prolongs service life up to 50000 hours, and can work for a long time.
No installation is required, just place the light where you need it and use it. It is very convenient to use.
Applications:
This LED light can be used for a study desk, bedside, computer desk, living room, bedroom, kitchen, cabinet, bathroom, etc.
More specifications:
Voltage: DC 5V
Beam Angle: 270’
2-in-1 Portable Camping Hanging Table Fan LED Light
3-mode / USB-C charging / stepless speed change / 270’ rotation / low noise operation
Power & Batteries
Batteries included: Yes
Battery capacity (MFG RATED): 5200 mAh
Battery type: Fixed
Input type: DC 5V
Power consumption: 1-6 W
Required battery count: 2
Estimated charging time: 4-5 Hours
FastTech 10th Anniversary Celebration: 15% off Site-Wide Coupon Sale
Dear all,
Good News! On the occasion of this anniversary sale, FastTech has prepared many activities with big discounts for our customers. It will be the greatest sale event of the year and definitely maximize your savings! SHOP MORE, SAVE MORE! Don’t forget to set alarms ahead of time, so you won’t miss anything!
————————- Anniversary Site-Wide Coupon ———————————
Offer: Site-wide 15% off
Valid Date: Jun 15, 2022 – Jun 18, 2022 (UTC-6)
Coupon Code: FT2022
———————————— Anniversary Giveaway —————————————
Enter to Win (Any Purchase of $30 or More)
Ends on June 19, 2022 (UTC-6)
———————————— Anniversary Order Gifts ————————————-
Random Free Gift!
FIRST COME, FIRST SERVED!
—————————- Extra 3% value on gift certificates —————————-
Customers can pay via PayPal or credit card for buying gift certificates to get an extra 3% free value instantly.
The Gift Certificate is good as cash, a fast and easy way to check out, you can use it to get anything you like.
In addition, gift certificates can be used in conjunction with other site wide coupon promotions. And the gift certificates are valid for 5 years from the purchase date.
Special Sale! Happy Father’s Day - Up to 25% Off
To the world, you are one person, but to one person you may be the world. Happy Father’s Day to all Fathers!
Let’s grab a present for father now!
Coupon Code: DEALS
Valid Date: June 19 - June 26, 2022 (UTC-6)
1500LM 6500K LED Flashlight w/Focus Zoom
XHP70 LED / 3-mode / 1*26650/1*18650/3*AAA / USB-C charging / IPX4 / 200-300m throw / window breaker
Beam range: 200-300 m
Flashlight modes: Hi > Lo > Strobe
Lens type: Convex Lens
Mode count: 3
Switch placement: Side
Switch type: Clicky
Zooming: Yes
Can this be turned on and off directly or do I have to cycle through all modes?
Rusty Joe, The flashlight will turn off after a long press.
SolarStorm D1E 800LM 6500K 80m Underwater Diving EDC LED Flashlight
L2 LED / 3-mode / 1*26650/1*18650 / 332m throw / 18500cd
Details:
Head diameter: 51mm
Tail diameter: 39mm
Beam range: 332 m
Flashlight modes: Lo > Mid > Hi
Lens type: High-Transparency Tempered Lens
Mode count: 3
Mode memory: No
Reflector type: Aluminum Smooth/SMO
Switch Placement: Side
Switch type: Clicky
Tail Stand: No
Thermal sensor/throttle: Yes
IMALENT MR90 50000LM 6000K LED Flashlight w/4*21700 Battery Pack
authentic / 8*Cree XHP70.2 & 1*Luminus SBT90.2 emitters / 8-mode / IP56 / 1586m throw / 629000cd
Details:
High-efficiency constant current circuit will maintain constant brightness.
Built-in thermal control module will automatically adjust the brightness output, keep using comfortably.
Aerospace-grade aluminum alloy body, wear-resistant Type III hard-anodized surface treatment.
Head diameter: 92mm
Tube diameter: 56mm
Beam range: 1586 m
Flashlight modes: Turbo > Hi > Mid II > Mid I > Mid Lo > Lo > Spot > Flood
Lens type: Double Side AR Coated Anti-scratch Optical Lens
Mode count: 8
Reflector type: Aluminum Textured/OP, Aluminum Smooth/SMO
Switch type: Clicky
Tail Stand: Yes
1*XHP70 & 1*COB 1000LM 6500K & Red LED Flashlight w/Focus Zoom
6-mode / 1*18650/3*AAA / USB-C charging / IPX4 / 100-200m throw / window breaker
Beam range: 100-200 m
Flashlight modes: LED Hi > LED Lo > LED Strobe > COB White Light Hi > COB Red Light > COB Red Light Flash
Mode count: 6
Switch type: Clicky
Zooming: Yes
“H4 5.75” 200W 20000LM LED Motorcycle Headlight”:https://www.fasttech.com/products/9759020
IP67 / fast heat dissipation
Details:
Operating temperature: –40 to 85’C
Life: 50000 hours
High beam: white light
Low beam: white light
Daytime running lights: white light
Turn signals: amber
