Couldn’t it be the 1919 CSP from the LT1s?
Wurkkos stated 23x23
Great to see the TS10 finally available!
Wurkkos:the main LED is CSP 6000-6500K and with >90 CRI tint
What plans are there for the next batch? 6000-6500K is quite cold for many and may hinder sales, even if it’s >90 CRI.
- If it uses the same CSP as the LT1S, for sure you will offer the TS10 with 2700K >90 CRI?
- What about mixes? 1x 2700k, 2x 6500k, or 2x 2700 + 1x 6500k? Rosy…
- Any non-LT1S CCTs planned? 4000k, 5000k?
- For the DIY-minded, Wurkkos could sell the CSP emitters though the website… Low-effort way to make the initial batch more interesting for some.
yes, we are planing use 4000K 5000K in following production, CSP emitters now only have some 2700K in stock, we will update on the website
dannyroll:If it’s this 2323 CSP emitter , it shares the same footprint as the E21a.
I ordered one red and one orange. I also added some E21As to my Clemence group buy. Hopefully the driver plays well with the E21As
different type from CSP, 2323 with more power compare with 1919
Wurkkos: Verodin:@Wurkkos
According to the announcement this light will be available in a few hours. Ignore our modding nitpicking details for a moment and at least tell us the CCT. It’s an essential basic detail of a flashlight. Thank you.the main LED is CSP 6000-6500K and with >90 CRI tint
Can you please tell us the exact product code of the LED?
the CSP 2323 data sheet from here
http://en.latticepower.com/NewsView.aspx?id=108
SammysHP: Wurkkos: Verodin:@Wurkkos
Thank you! Looking forward to a review with color and CRI measurements!
@Wurkkos, is there plans to have 14500/AA compatible version?
Not sure, if it is compatible with AA, it will lose some performance and the output will be less
I just got a word with Clemence (ERKX), showed him the emitter datasheet and he said it could be a straight Nichia E21A swap. Not 100% sure because i don't have it on hands but soon (hopefully) i'll report back with some mod update. :)
Man these emitters are skinny! If you’re going to mod, get out your super fine hair tip tweezers. Data sheet isn’t all that encouraging, compared to emitters we are used to using. The reflow characteristics hint at users being able to do it right and do it quickly, and be able to control the temperature decently.
Specs say a total thickness of +/- 0.32mm. That’s including the phosphor. That’s about one half of a B35AM and those are pretty thin! For the SAE among us, that’s about 0.013”, thirteen thou….1/64” is about 0.015”. Looks like the base is something around half the thickness (phosphor being the other half). Sounds easy to damage the edges/surface of these with typical small electronics tweezers. Also seems like a candidate for using a stencil with solder paste…those pads are teeny tiny.
lotari:Great to see the TS10 finally available!
Any estimate on when those other CCT options will be available? Also Ice Blue and Orange sold out, I shouldn’t have waited lol
So my house was robbed last week and they took my KR4…I came on here looking to find a reasonable replacement and sure enough, here it is…but it looks like I missed out on the Orange one. Any ETA on a new batch?
I can solder very well, what size are the aux LEDs?
Orange with a battery seems to be in stock still. Orange without a battery is out of stock along with both options with ice blue aux. Even if you don’t need the battery, it’s only 2 bucks.
On their site? I see Orange and Ice Blue as being out of stock no matter which options are selected.
Wurkkos: lotari:Great to see the TS10 finally available!
OPS, sorry when going to update the 2700K CCT, i found it was 1919 size, so have to wait next batch of other CCT options
I just got a word with Clemence (ERKX), showed him the emitter datasheet and he said it could be a straight Nichia E21A swap. Not 100% sure because i don’t have it on hands but soon (hopefully) i’ll report back with some mod update.
Thanks!
Good luck with the mod. I’ve swapped the TX in an i3E. One hit and one miss. Three tiny LEDs at a time will be very difficult I guess.
10 more blue color release from the unpaid orders.
So, this light uses a buck driver, right?
I’m pretty sure it’s linear. 14500 only.
~~ROYCE~~:Orange with a battery seems to be in stock still. Orange without a battery is out of stock along with both options with ice blue aux. Even if you don’t need the battery, it’s only 2 bucks.
It was definitely listed as in stock when I checked yesterday, but no longer. Blue is back though.
Does anyone know if this light requires a flattop/button top cell? Or if either will work just as well?
