Awesome! Would be really nice if we can develop some sort of BLF spectrometer that’s better than the Opple
I’ll see if I can create some CSV files that have the calibration matrices. Then they can be shared and don’t need to be created multiple times. Don’t know about Python, but it’s not too tricky to read those in C.
Note that there are 3(!) different versions (“Based on Full, Production-Wide Device-Characteristic Dataset”, did device characteristics change over time?);
v1.1 (2019-02-13)
v3.0 (2021-04-28)
Initialization data that comes with AS7341_EvalSW_ALS_v1-26-0.zip
This is the one I’ve seen used, it appears to be a combination of those two:
n = (x - 0.3320) / (y - 0.1858)
CCT = 449 * n^3 + 3525 * n^2 6823.3 * n + 5520.33
Btw, I’ve switched from using all channels (excluding flicker) to using only F1 to F8 as input (the clear channel overpowers all other channels, NIR seems pointless for flashlights). Don’t know if and how that affects results. Any thoughts as to what would be better?
This is an awesome project! I’ll have to order myself an AS7341 to have a play with too.
Might be better off getting something like a bit of Lee Filters 250 Shouldn’t be too hard to source small sheets, and probably more consistent than Ali.
Interesting project! I tried this a couple years ago and got really frustrated with the results, but I’m afraid I gave up too soon. My readings seemed to jump all over the place. I think I tried using a diffuser, but it’s been too long so I don’t remember exactly. I’d love to have another go at this at some point.
Time for another update: I’ve made quite a few changes to the code. Refactorisations and cleanups, bugfixes, added more verification code and the basic calculations for spectrum reconstruction (the large calibration matrix and spectrum to XYZ). So if you have a clone, just get the latest code.
The good new is that readings seem to be much more consistent now that auto gain is used. However, reading are off by about 500K (too low), consistently. This is a bit of a mystery, since the AMS excel gives the same results when inputting the raw readings from the sensor. This leads me to assume all calculations are correct, but the raw readings must be wrong somehow. My guess would be integration time is not correct, since that’s the only thing that I can think of that influences the raw values returned. Needs further investigating.
That would be great for fine tuning, thanks for the offer! I’m in Sweden. Currently still having issues getting the reading close to actual CCT, so it might be a bit premature (see above).
As part of the Eurkatronix group GS5 buy I ordered the whole range of E17A CCTs (sm1863c, sm203, sm223, sm273, sm303, sm353, sm403, sm453, sm503, sm573 and sm653), specifically for test purposes. But they don’t come with (detailed) SPDs. The closest data is the test reports on the website and that’s probably close to the actual LEDs I’ll be getting. If that works out (including a proper physical test setup), I’d love to fine tune using a real reference LED.
Did you use any form of auto gain? I initially had the same issue, just couldn’t get consistent readings, unless I looked at the raw readings and adjusted how I held the flashlight at a certain distance and brightness. Results are much more consistent now that the sensor decides what gain to use. There are slight variations when I move the light sideways, but nowhere near the huge jumps in CCT as before.
Just pushed a change so it uses the ‘higher accuracy’ spectral calibration matrix by default. Define USE_XYZ_CALIBRATION_MATRIX in SpectralSensor.cpp to use XYZ calibration matrix as before.
And for those wanting to output the reconstruct spectrum to CSV, check out the Spectrum::saveToCsv() function. It’s primitive, but it works (need a GUI at some point…)
No, I don’t think I did. I really should dust this project off again and try some more things like that (or rebase it on a newer sensor, like the one you’re using).
Any chance you can (digitally) provide a SPD and corresponding CCT and CRI values? Preferably 1nm steps, but 2nm would be fine as well. Possibly one above and one below 5000K (for testing Planckian and D illuminants).
Reason I’m asking is that I’ve started working on calculating CRI values. Having this data allows me to verify if the calculations are correct based on known values, independent of what the AMS sensor produces.
So for the past few days I've been sinking my teeth into the whole CRI thing. It's a lot of info/data to take in, but I think I'm starting to get the hang of it a bit. Going down the rabbit hole further, but it's interesting stuff. But I've ran into another issue. I've been using Osram's ColorCalculator as a sanity check and found that my CIE1960 v value is way too low. This results (among other things) that the chromaticity distance is too big and CRI results are meaningless. Osram provides a few example spectrums, so I took the included "White (2700K)" and used that as input. If all is well, the result should match right? But nope...
See screencapture. Look under preparing test SPD. And ignore convert output part under Calculating CRI. Most basic values are close enough (CCT, xy and u), but the v value is way off:
Now this makes no sense as the calculation from xy to uv is pretty straightforward. As per Wikipedia the formula is:
In my code this is done like this:
// MacAdam simplified Judd's double n = 12 * xy.y - 2 * xy.x + 3; u = (4 * xy.x) / n; v = (6 * xy.y) / n;
I went down a similar rabbit trail that lasted several months and ended when my son was born late last year.
The most promising thing I found was a bit more DIY in terms of the sensor, but perhaps useful from at least the GUI standpoint:
The upside of the more involved hardware approach is that your resolution can be an order of magnitude greater than the adafruit sensor. If I didn’t have a Xrite Colormunki, I would have already built one myself.
