ChibiM
(ChibiM)
June 2, 2022, 10:31am
842
After so many years, finally a new Eneloop battery.
Besides a new kinds of packaging for the Eneloop Lite and Eneloop PRO , the 5th generation standard Eneloop White has just launched in Europe .
Thanks goes to one of our readers, Daniel.
Minimum 2,000mAh , but same cycle life
Thanks for the update! You know there are whole bunch of flashlight reviewers these days, but when it comes to Eneloops, you’re the man!
roostre
(roostre)
June 2, 2022, 3:32pm
844
Thanks for the update ChibiM.
Did the capacity of Eneloops improve for the 5th generation standard Eneloop White?
Interesting that the new packaging states "NEW CAPACITY min. 2000 mAh" and "NEW CAPACITY min. 800 mAh" (but there is also a *1 symbol next to the word "min." and I wonder what that means).
For Eneloops I have recently purchased in the USA (I'm not sure which generation they are):
The packaging for AA Eneloops lists "Capacity up to 2000 mAh" and the battery wrap on the AA Eneloops states "min. 1900 mAh":
https://www.amazon.com/gp/product/B00JHKSN5I/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
The packaging for AAA Eneloops lists "Capacity up to 800 mAh" and the battery wrap on the AAA Eneloops states "min. 750 mAh":
https://www.amazon.com/gp/product/B00JHKSMIG/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
Pip
(Pip)
June 2, 2022, 5:25pm
845
The *1 is probably linked to some fine print on the back of the package, as well as the *2 after recharge up to 2100 times.
ChibiM
(ChibiM)
June 3, 2022, 7:07pm
846
In Europe, our Eneloop packaging shows Min. capacity only. This has been the case for many years.
I thought that the US also changed that, but it seems not. So they still show Min. capacity + Typical/Rated capacity.
The new AA will do 2,000mAh instead of 1,900mAh
and the new AAA will do 800mAh instead of 750mAh.
These are only available in Europe.. for the moment.
I just ordered 4 AAs and 4 AAAs.
ChibiM
(ChibiM)
June 16, 2022, 9:08am
847
No, I got them at Amazon.. Nkon will probably have them soon as well.
arow55
(arow55)
June 18, 2022, 5:33am
849
Could someone measure the diameter compared to older generation. I have some devices that are a tight fit. Wondering if the extra capacity requires bigger battery.
ChibiM
(ChibiM)
June 18, 2022, 10:12am
850
Unfortunately, I have a cheap digital caliper, and it's not so precise in the tens/hundreds of millimeters.
1st gen 14.11
3rd gen 14.13
4th gen 14.13
5th gen 14.16
These measurements aren't static... Each time I measure, they change slightly in the tens/hundreds, and sometimes go up to 14.20mm.
But every time I measure them, the 1st gen has the lowest number, and 5th has the highest number
Thank you for the heads up & the video ChibiM …
arow55
(arow55)
June 18, 2022, 6:20pm
852
Thanks much for measurements.
agungz
(agungz)
September 1, 2022, 3:14am
853
is this special eneloop edition is original?
https://www.adorama.com/byseaag4.html
https://www.seedcamera.com/Battery-Charger/Eneloop-Glitter-AAx4-Two-Tone-HR-3UTGA-S4G.html
it seems to original, but 4 pcs per pack
I read your blog and these kind of eneloop has 8 pcs per pack
ChibiM
(ChibiM)
September 1, 2022, 7:23pm
854
Hi,
They are kind of unique, but not a special edition.
The actual special editions are called Tones, and are numbered from 1-4 or 1-8 depending on the type.
agungz
(agungz)
September 2, 2022, 6:56am
855
ChibiM:
Hi,
but that unique version, is it still original and not fake?
ChibiM
(ChibiM)
September 2, 2022, 7:05am
856
Yeah, they look legit.. I think they are 2nd gen Eneloops
cyclops
(cyclops)
October 28, 2022, 1:51pm
857
What about these batteries sold on costco? Since they are made in Japan, are they rebadged eneloops as well?
raccoon
October 28, 2022, 1:57pm
858
@cyclops:
Those are not advertised as being LSD.
In my experience, if a battery is not advertised as LSD, it's not LSD, therefore there's no way that they're rebadged Eneloops.
flydiver
(flydiver)
October 28, 2022, 2:11pm
859
The Energizer are confusing. I was under the impression there were made in Japan, and there is only one factory making AA in Japan. Mistake? Misinformation?
Also [Made with 15% recycled materials] and [These Energizer AA batteries come pre-charged and can be recharged in an Energizer battery charger hundreds of times. Each AA rechargeable battery can hold its charge for up to 12 months in storage, and the double A batteries have up to a 5 year battery life with normal use.].
Those claims are not consistent with Eneloop.
Hoop
(Hoop)
October 30, 2022, 12:09am
860
Looks like 5th generation Eneloops are still not being sold in North America.
ChibiM
(ChibiM)
November 18, 2022, 12:59pm
861
Right now, still only in the EU!
