ACEBEAM New E70MINI Ultra-compact&powerful 3 x Nichia 519A EDC light for outdoors, working, commuting,etc. Diminutive and finely crafted combined with high performance make the E70 MINI ideal EDC Flashlight too!
Utilizes 3 x the latest popular high CRI Nichia 519A LED for a maximum output up to 2000 lumens
The high CRI>90 Nichia 519A LED produces a uniform and smooth spot with no artifacts, capability revealing every detail on objects
Neutral white (5000K) uniform spot reducing chances of misdiagnose
Powered by 1 x 18650 rechargeable battery with max long runtime 56 hours
5 Brightness levels and 2 special modes (Strobe and Ultra-Low) for various scenarios
With a stainless steel clip can be attached to pockets
Stylish double layers tube design for better grip and heat insulation
Lockout mode and “double click to turn on” design prevents accidental activation
Rating in accordance with IP68 (2 meters submersible)
They probably got rid of the reverse polarity protection FET and dual sense resistors for space saving, having to use physical RPP (only button) and higher minimum.
Perhaps your original analysis is also why they did not even try for a legit moonlight mode. If the best they can do is 7.6% efficiency, why even bother?
E70 MINI is powered by 18650 battery (Recommended ACEBEAM ARC18650H-310A with PCB and Built-in USBC Port ).
Note: Do not use the batteries without circuit protection. Flat-top battery without protection is designed for industrial applications, not civilian battery and must be treated with cautions and handled with care. Only use quality batteries with circuit protection will reduce the potential for combustion or explosion.
If you have 18650 battery with PCB and the size length 65MM, it also fits for the E70 MINI.
E70MINI utilizes the latest popular Nichia 519A LED Emitters, produced a uniform and smooth spot with no artifacts, capability revealing every detail on objects, equipped with the customized TIR optic lens, can reflect uniform and soft light, is the perfect everyday carry companion.
There’s a spring on the driver, so any battery will do. But there’s the contact for the inner tube around it and therefore a chance that a large contact surface on the battery will connect to it. Seems unlikely but one never knows. I didn’t dare to try it out.
Btw, love this light. Especially the LEDs are really good, very close to bbl.
