I found this on the threads in the head of my light, like the drill bit was tilted… in 2 places. Screws on ok, but still… Still can’t get auto lock enabled. Does the stock firmware even have it?
Finally got autolock on… button must be pressed very squarely to take accurate counts. I really love it and am thrilled by the first 6000k that I like!
Not officially, Toykeeper probably wasn’t even involved in the development of the TS10. I have made my own hex that fixes this issue and can share it if anyone wants it. It is basically just sofirn-sp36-t1616 with a single line of the code commented out.
The big thing that feels different to me is the lack of blue and glare. The cri does not hurt either. At high drive the Duv actually goes ever so slightly negative as well!
Can those of you who have the light post some pictures? Specifically:
What does the button look like?
Beam and beam pattern?
Side-by-side with an FWAA - based on the picture someone posted with an SP10Pro I think this Wurrkos is shorter than an FWAA, but it would be nice to have a side-by-side photo to compare.
thanks for the photo of the TS10 flashing pads (I used a clip of your pic below)… looks like they will work with the TTL Pogo adapter that gchart made for the SP10 Pro…
note the TTL is modded by gchart, it is not stock
I would like it please… should I pm you my email? might be good to give it to Wurkkos too
US $19.99 30%OFF | Wurkkos TS10 Mini Powerful Flashlight 90 CRI 3* CSP +3* Aux LED Emitter 1400lm Anduril 2 Pocket Torch Waterproof EDC for Hiking
They are releasing a new host color(red) and a ww LED (4000k) for all those who were turned off by the limited new product release.
Wurkkos is really listening us as enthusiasts. Treat them with the respect they deserve
Here is the link to the custom hex file which fixed the aux led bug. It is built on the latest revision 650, so I labelled the firmware version 202204290614.
