Many years would go to a private lake and much fauna would observe me. Never had any bad encounters – question of keeping my distance. Duck family would usually make their home, only to be shot down come autumn. Imagine, it’s not as the locals need these to survive and they are quite helpless being young and never have taken to much flight.
Had a curious moose follow me on the forest edge, just shy of being seen. Heard him though, and saw the lower branches move then eye contact. She moved on.
Many other small critters but my favorite was the deer couple that came for a drink. The buck would watch over as his doe would sip, then take turns.
Small black bears would occasionally be scrounging some berries in some open space, raise on their hind legs and take a sniff of my presence. Go back to hoarding and that was it.
I’m trying to make what prompted such an incendiary calamity.
Clearly see some pressure relief valve blowing some sort of liquid. Would hydraulic fluid be so volatile and why wouldn’t the press designers release it into some containment vessel?
Man, that ended up like a blowtorch aimed right up at the ceiling.
It probably ended up like an oil-burner, ie, a fine mist of oil (hydraulic fluid) that just ignited and kept going. Hard to start up, but once heated and/or aerosolised, VWOOOSH!
Your comment on the “pest control (cockroaches)” got me digging for this vid.
I’ve worked with plastic injection presses and this isn’t one. Seems like a 1st world installation; all very clean and tidy. The fellow with the oxy-acetylene torch isn’t anywhere close enough to ignite the spray – lest I can’t see any jump to such.
Sheesh…I did not expect such a consuming fireball! Seems like it ignited on something floor-level to the back right of the machine. Kinda neat to see the rectangular flame outlines from the insulation batts after they hit the floor. Glad those two hightailed it out of there…I probably would have been standing there ready for incineration.
Amazing the security camera stayed live and in focus – a proper set-up with an independent power feed.
Had one incident with one of our presses where the nozzle blew. Heavy composite of glass fibre polyamide that overcooked and plugged it. Shot out with a very loud bang onto the bolster die plate. No harm was done but the release of a dark black sooty cloud got the shop evacuated. I was near, too close actually. Lost my hearing for the afternoon.
Operator error, was supposed to dump any residual load before lunch break.
The draw on that press is long, maybe 30 feet *. The controls on the bottom right are heaters/coolers. The overhang ducts are for fumes. Can’t see any gantry/overhead crane and can’t make what’s on the floor, coiled. I don’t think a hydraulic failure is the culprit – those are a short burst (they do make mist though).
*Edit:
Draw perhaps 5 to 6 feet. Ducts don’t seem to be directly overhead the press but rollers are in line. At second look, the press would have completed its open stroke and the pressure valve then releases.
Wow! Insane. Curious—it was just posted yesterday, as an unlisted video, and comments are turned off. No explanation in the description section.
It would be interesting to understand the “generally expected” volatility risk of that factory. Were they dealing with volatile materials at all, or was this scenario completely unexpected? Notice how one guy goes running back to the control console to grab his phone and he briskly walks away, not running fast… until that fire rapidly expands. THEN the two guys run full speed. The heat must’ve been pretty serious. Can you imagine if one of them tried to rescue the computer at the control console? They would’ve been engulfed by the fire.
The hydraulic fluid (?) spewing out of the top of the press like that… looked like firehose volume… must’ve rapidly spread over the ceiling. It’s crazy how fast the ceiling materials caught fire and then came raining down.
Aluminium extrusion factory in Seville, Spain Thursday, June 2nd, 2022 Reddit
And redirected article from CanalSur (Radio & television) link
However they say the fire started in the ceiling – clearly not the case.
Metafilter has more probable cause to hydraulic fluid atomized: link
Now I better understand the machine is an aluminium extruder; billets coming from the left and the final shape out on the right. The “coils” are the dies, the ducts for the cooling and any oils/vapours coming off. The operator was perhaps about to replace a die and had the machine open up. Something went wrong and the hydraulic pump went full flow. *
*Afterthought: hydraulic pumps deliver little flow but rather pressure – so maybe some other fluid.
My only experience with this type of machine was on a tour of Alcan in Kingston. Ontario. The billets and the end products were all on rollers and laterally to the extruder (unlike this set-up where they are in line). The billets were pre-heated with natural gas and I suppose this would have been the ignition source here.
Good find. Curious… the place looks much less sooty than I would’ve expected… unless the aftermath shown is after a certain basic cleanup had already been performed.
I’d pay good money to have hands as steady as this guy…
And to think Rolex refused to work on this ladies watch.
Just like so much in this world - nobody to step up and do things right.
All the Best,
Jeff
Kept me glued to the screen. visually and auditorily captivating. Not only a steadiest of hands, the chronological order of re-building – without a single error. This guy has seen many watches; almost a lost profession.
