I picked one up, hopefully it’s worth a hoot. Does anyone know if the 12” is the cage width or actual blade diameter?
A bit concerning that a device with so many lithium-ion cells does not appear to be labeled anywhere with standard li-ion caution language - the manual that is available for download from their website does not give any cautions whatsoever, nor is the word lithium mentioned a single time. I don’t know if that UL cert number is valid…appears to belong to another company in China but could be the same. Don’t see any other cert symbols on the unit, media, or manual. They seem to lean on that FCC interference thing instead.
Hopefully Sunvalleytec Int’l and the heads of their many sub-brands figure out how to fairly and legally participate in the markets of the countries they do business in (and looking at other lawsuits, also figure out how not to infringe on patents and such…). They have some good products.
It’s a wall wart with a barrel connector…rubber flap for the port on the right side of the box. Manual states 110-240 input with DC 30V output, 24W. 0.8A consumption on the fan label. Apparently it will operate under wall wart power, too, which is nice.
Not sure if the cells are in series or parallel (30V adapter suggests series, which is kinda scary), but worst case, if there’s any issue with the cells, I can pull ’em and work directly off the adapter.
Gawd, what an annoying website, though. That coupon box (which dumps piles of 3rd-party cookies on you) that pops up Every Single Time was getting me on-edge to the point I was almost about to ditch the transaction entirely.
Still, looks like a solid fan. Goggled it on amazon, looks pretty nifty. I’m assuming 22hrs runtime is not going full-tilt, eh?
This is one of the images from the Walmart listing. First one I’ve seen with a good comparison for the size. Looks like the perfect size for what I need it for. Glad I bought one.
I wonder what type of cells it uses? I couldn’t find an answer online. From the reviews, it seems to run about 1.5 hours at the highest setting on a full charge and much longer at reduced power. I assume these are NOS (new old stock), so the cells could be quite old and no longer hold a full charge. I ordered one, so I guess I’ll find out soon enough.
A similar fan with good feedback would be at least $50 a piece, so if TaoTronics cancels my order, and I think they probably will, I'll just go without a nice rechargeable fan.
