Wurkkos TS21 tear down
133 posts / 0 new
TheIntruder
Last seen: 1 week 3 days ago
zoulas wrote:
TheIntruder wrote:
That’s unfortunate.
The issues were acknowledged, with fixes promised, but no results, and no response to a direct question about plans to execute.
In my book, that’s not “great” by any means, and part of the reason why I’ve found it easier to divert my energy, and money, away from the budget flashlight hobby.
Same-old themes keep repeating themselves.
That’s a bit extreme, no?
What’s extreme?
Expressing disappointment that a manufacturer has been hesitant to fix a light with a acknowledged deficiencies, if not flaws, yet continues to manufacture and sell it? The abnormally high drain is not the only one.
Or simply having found other things that pique my interest more?
I’ve got all the lights I need, but the bar for something I’d want is higher. And “budget” or not, that does not allay the need for standards, if only of a personal nature.
Even if many are willing to accept playing beta testers with saleable products, not uncommon for this market, passes shouldn’t be given for not providing patches. The crowd that hangs out here is not the only one such products are sold to.
Light Veteran
Last seen: 4 days 20 hours ago
Mine has the same issue
•12,97 to 13,97 mA on high
• 0,17 to 0,50 mA on low
• 0,11 to 0,44 mA in off
The numbers are not stable.
You can see a little cycle from the first number to the last number like a jump and back
For measure I use a Fluke 179. I know I don’t have uA but in mA I think is precise
Very bad news for this light
Flashlight addicted
willc68
willc68's picture
Last seen: 1 week 1 day ago
My TS21 is probably 3 months old and luckily I don’t have any problem with parasitic drain.
On high setting the current draw read .9 micro amps and on the the other switch light settings my meter read 0.
I probably put a fresh 21700 in about a month ago and I got 4.09v on the meter. Which seems about correct as it only gets used a short time on work days.
I am curious as to whether it is a problem with the driver or the software.
Anduril does get updates and manufacturers also use different parts lots so it could be either one.
JagerLion
Last seen: 2 weeks 2 days ago
how crazy is this wrote:
I wonder if it is manufacturing inconsistencies or perhaps the intended fix worked out being worse than the original problem. I have one of the first Andruil 2 units with the sst-20. IIRC, the drain was similar to what was noted by Tom. Not a problem for me when set on low and I don’t mind the very low light level at all. However, that level of drain is no where near 3 mA!
I’m leaning toward inconsistencies. Several reports ranging from “meh not so good” <300uA to (in my case) “pretty much unusable” 3+mA. I’ve heard nothing back from Wurkkos and it sounds like nobody else has either. I’ll not be purchasing Sofirn / Wurkkos for a while in case the same issues creep into other lights. And I’m no hater. I have several Sofirn / Wurkkos lights and really like them.
I shoot magic into the darkness!
zoulas
zoulas's picture
Last seen: 8 hours 5 min ago
Is the problem with the Anduil 1 or Andruil 2 version or both?
Light Veteran
In my case is Anduril 2
Flashlight addicted
pennzy
pennzy's picture
Last seen: 10 hours 49 min ago
The drain jumps around on the meter. There is a bug causing it and probably related to the button light jumping around bug.
JagerLion
Mine is the 219C Anduril 2 version as well.
SammysHP
SammysHP's picture
Last seen: 10 hours 8 min ago
That’s not a firmware bug. The boost regulator for the powerbank function pulses regularly because it has to check if there is a device connected.
Light Veteran
Thank you for explaining this..but..why it has to check if a device is connected?
In this mode it drain battery more fast but I switch off the led button..I don’t like color
Flashlight addicted
SammysHP
SammysHP's picture
Maybe not only the powerbank controller. Anduril wakes up several times a second to check the battery voltage. That will increase the power consumption as well. I’ll take a measurement (of a different anduril flashlight) later.
SammysHP
SammysHP's picture
Here are some measurements of an Emisar D4v2 Tintramping, done with a 100 Ohm shunt resistor.
Aux LEDs off:
Aux and switch LEDs blinking:
