you can find for any light a level that runs for 3 hours
it will not be 1000 lumens though for an 18650
more likely about 300
the cell holds maybe 15 watt hours
for 3 hours this would be 5 watts
3-400 lumens guess
though that is pretty bright
3-400 lumens guess
If you are not married to 18650s, take a look at the Convoy S21A.
Only slightly larger than the S2+ but takes a 21700 battery.
A bit more output is possible, but the bigger gives longer runtime.
All the Best,
Jeff
If you like a lot of things about the 1L, have you checked out its larger (1x18650) sibling, the 2L(-X)? I use a Protac 2L-X and like it.
Thanks for the suggestions, I’m going to check it out! My apologies. What I meant was a total runtime of 3 hrs with step down. And the reason for this is that it’s probably the most realistic usecase for me during a first aid duty where sometimes I need to go out there in the woods or open fields with zero to no lighting. So I’ll need some throw to reach out and then use the spill to work when I located that person.
My technical knowledge is too limited to go for modding, so I’ll need to pass for that. When looking at compromises, momentary on is something I can forego.
I’ll skip the UV-feature. That was just a bonus to play around with. With regards to ‘high’. I’m looking at at least 5000 candela like my 1L which has 275 lumens, so any thing above say 300 is high (enough).
Thanks for these suggestions as well. If they use 16340, it’d would surely help to soften the finance in buying new batteries every few weeks. Runtime wise, having a spare battery during first aid duties could ‘work around’ the runtime limitation I think.
Thanks!
Thanks, I’m going to check this one out as well.
I saw Convoy come by a couple of times on this and other forums. But I always get lost in the amount of customization possibilities.
Yes, what I meant to say that it should last 3 hours with step down starting from high. It’s going to be the most ‘realistic’ use case for me (get a call to for a first aid response. Go out in the field and try to find that person with the light and using the light to work and say have 2 or 3 of such cases in night time near zero lighting).
Not per se married to 18650, but felt it was the ’ best’ compromise of size vs. durability. I’ll check the 21A out as well. Thanks!
Didn’t look at those yet. I’ll check them out as well!
The S21A is hardly much bigger than the S2+ and the runtimes/output are better, and it’s great quality for the price, so it gets my vote.
As far as the customization goes, I have one with the B35AM 4500K and one with the 519A 4500K. Can’t go wrong with either IMO, although I find the beam of the B35AM to be slightly whiter, and the 519A to be a bit more yellow, so it just depends on your taste.
So many options, where to begin.
All of the feedback you get will likely confuse you more.
“Didn’t look at those yet. I’ll check them out as well!
[/quote]
It’s essentially a 1L that uses 18650, so a better question might be ‘what don’t you like about the 1L’ - you didn’t mention any ‘don’t likes’. Keep in mind that the 2L-X is everything you like about the 1L, with more of everything you need (want): run time, lumens, candelas, etc., without giving up anything you like about the 1L except, obviously, size.
I gather you’re a professional user in situations where reliability / durability are a top priority, not unlike me. With a 2L-X, you also wouldn’t have to give up Streamlight reliability, and specifically the FL1 2-meter impact rating your 1L has (and be aware that by FL1 definitions: 2>>1x2). You’re unlikely to find that ‘feature’ with many other lights being discussed, so thought I’d mention it.
A very nice 18650 light is the wurkkos fc12. 10x better than the S2+.
I keep thinking Emisar KR4 with XPL HIs. High in Muggle mode will probably exceed the output of that Streamlight.
This won’t be a popular recommendation as it’s not “budget” but consider the Streamlight 2L-X. On your requirements:
I'm not a Streamlight fan since I consider them not a really honest company. They have for years and years BS'd their customers as to what emitter is in their lights to avoid any real valid comparisons. their user interfaces are somewhat stone age, battery packs proprietary and pricey . When you can have a sc21pro for close to $25 or numbers of Convoys for about $20 with a slew of High color rendering options I'd steer clear of repeat buying a Streamlight .
If the 18650 version is the same as the 1L Why wouldn't you spend $20 ~$30 just to see what else is out there.
Sofirn / Wurkos or Convoy .
My suggestion is a High CRI version of a Convoy S2+ or a S21A in green (probably one of the best color green anodization out there)
Convoy S21a 519a R9080 High Cri,21700 Flashlight ,torch,6amps - Flashlights & Torches - AliExpress
A quick view of hi cri lights from convoy / I'm sure Simon will put any emitter in almost any light for you free of charge if you ask .
Get a clip and a battery if you need one .
Beauty of modding an S2+ is it's as simple as pie . which means it's 100% upgradable and totally fixable by anyone with 8th grade school skills ..they are like 6 pieces :)
Sometimes a simple interface is preferred. Nobody should want Anduril on a rifle light for example, or IMO, a duty light.
The 2L-X will take any button-top 18650, though I’d recommend protected as it has no LVP. Their branded 18650 is admittedly overprice and low capacity.
The other criticisms are valid.
- i don;t know why
mine always comes on right where i left it last time
then it goes up or down like i want
usually i have it set for 8 levels
that seems to balance between fine light control, and speed of going to the other end of the range
wle
“Simple” does not necessarily mean “better” when it comes to UI.
I think a Convoy S21A with SFT40 and 12 mode driver will suit your needs paired with an SMO reflector. You can easily customize the modes to get it to do what you want. Sure, you miss out on high CRI and onboard recharging, and they are certainly longer than many other 21700 lights but I love mine as it strikes the perfect balance for me. These are very durable so will be excellent in field use and will survive many drops and is easy to repair. Can also be had with various Nichia options for high CRI but you will lose output and throw.
If that really is too big then get an S2+.
If you can go for something slightly bigger then a Convoy M21B with an SFT40 and 8A 12 mode driver is a nice thrower that has good spill. I use one as a bike helmet light.
21700 cells typically have around 40% more capacity than an 18650, and are only 3mm wider (diameter) and 5mm longer. A very worthwhile tradeoff. One of those would be very nicely paired with a Molicel P42A, P45A (if you can get one) or even the NCR21700 (5AH capacity for great run time).
If you need UV, keep in mind that almost all UV flashlight emitters are crappy 395nm so do yourself a favour and spend the extra and get a Convoy S2+ with the Nichia emitter in a purple host.
I’m not really a big fan of any of the Convoy UI options, but they are very functional and simple to use. PLEASE SIMON, I BEG YOU, PLEASE START USING ANDURIL!!!
The Sofirn IF25A with quad SST20 4000K is a very nice light with high CRI but draws around 18A on turbo and the heat output on higher modes is insane. Output is not that impressive for the current draw but it’s still a very nice light with Anduril.
/rant over
Correllux mentions the SC21 Pro. It’s the only one with assurance that it “can withstand earthquakes”.
/rant over
“These are very durable so will be excellent in field use and will survive many drops…”
What sort of FL1-compliant Impact Ratings do those offer?
[quote=Desertcat]
How is that relevant to this particular use case? I saw no mention of such a requirement.
There is plenty of evidence of the solid construction of Convoy products and the ease of repair along with a wide range of high quality replacement parts. I would rather buy several backup lights than pay for an irrelevant rating, and still have change to spare. ANYTHING human made is prone to failure. Better to get a backup light than to buy something with a fancy rating and then rely on a single point of failure.
I bet most manufacturers would not feel any need to spend money on certifications that very few of their users would require, and by insisting on such ratings the number of products available is significantly diminished anyway. Why artificially limit your options for no good reason?
Many thanks all for your input. Been searching and comparing a lot!
With my ‘requirements’, the perfect light doesn’t exist. Currently, one of my tradeoff is that I’ll tolerate a larger light and omit the two way clip. I do need the momentary on tailswitch, which unfortunately drops all Convoy lights from the table.
Streamlight 2lx is fine. Given the simple UI and size, but when comparing to other 18650 lights. I feel like I’m leaving lumens on the table. Especially for the price I’m paying.
Which regards to modes. I only need like turbo/ high and mid/ low. And start at immediate turbo. Strobe, sos or anything else is not needed. Maybe even a downside. When under stress. I really want to have all the lumens at my disposal with just one click. Fine motor skills is the first thing that goes out of the window when under intens pressure. I don’t want to double click something following single click something to have turbo (so to speak).
The fc12 looks appealing. Same with the sofirn. Especially, the sp31 v2 (as I read somewhere on this forum that the sc31t and sp31 V2 are similar but the V2 runs less hot?) Both have more modes than I need and I’m not sure if they can start on turbo, but both have a battery indicator which is a plus. Compromises again…
I think I have a small preference for the V2 compared to the fc12 due to the V2 have a bit more spill and also is a bit smaller.
And quality is a must, to a certain extent and I prefer to lay a bit more when I need to, but I doesn’t need to be professionally certified. I also don’t want to spend a couple of hundred bucks on a light which I may accidentally lose in the field or which will have a high chance to become dirty in the field.
Still debating with myself here.
Thrunite TN12pro ticks a lot of boxes
