i can send some TIR lenses to your for free, just note this in the remarks.
About the 12A FET driver, The manufacturer didn’t want me to sell this driver. You can consider the new version of 8A 12 groups driver.
Simon Mao:S21D with 12A FET driver on sale now
S21D
S21D with batteryCan we get beamshots of the different optics?
OK, I’ll take some time to take some pictures.
@Simon, any idea when the SFT40 5000-5700K and the new 17mm 6V boost driver will be available?
LUMINUS may not produce 5000-5700k sft40,
I got 17mm 6V 4A driver sample , But I’m not sure which LED to apply it to, what about XHP50.3 HI ?
17mm 6V 4A 12group could be set to 50% group and used with B35? Or make a 3A version?
Or drill out a reflector and put XHP70.3 in a S2+/S3!
lg.tech:@Simon, any idea when the SFT40 5000-5700K and the new 17mm 6V boost driver will be available?
Too bad about Luminus not producing the SFT40 in lower CCT’s.
As for the 17mm 6V 4A driver (12 modes). The XHP 50.3 HI is exactly what I intend to use, in 5000K with OP reflector. Essentially, that’s my build plan for my upcoming S2+ MAO or Ti in 18350! If I could get that already built by you that would be supper! :sunglasses:
I just looked at the S3 and noticed the new batch also has rectangular threads… Simon, can we use the 18350 rectangular thread tubes from the S2+ with the new batch S3?
I think XHP50.3-HI is an excellent choice. Will you stock it in multiple CCT’s? I would love to install it in a C8+ in 4000K.
Does it mean that the S21d running the 12A driver will be hotter than the 8A previously?
When do we expect the 8A buck driver to be in stock?
Agreed, xhp50.3 HI would be a great choice, especially if some warmer color temps will be available.
Simon, do you know what the coating thickness is on the MAO finish for your lights?
Also, have you noticed or tested thermal performance with the MAO? I’m reading that it can drastically lower thermal conductivity compared to anodizing depending on the thickness and the type of alloy. Of course it’s on the outside from where the heat is generated but just curious.
If you need a 17mm B35AM driver, I can produce a 17mm 6V 2.2A dedicated driver.
It is more dangerous to use a 4A drive.
yes, thread is suitable ,but the S3 is a little blunish ,the S2+ 18350 tube is a little greenish
Simon Mao: lg.tech:@Simon, any idea when the SFT40 5000-5700K and the new 17mm 6V boost driver will be available?
I got 17mm 6V 4A driver sample , But I’m not sure which LED to apply it to, what about XHP50.3 HI ?I think XHP50.3-HI is an excellent choice. Will you stock it in multiple CCT’s? I would love to install it in a C8+ in 4000K.
I don’t know why XHP50.3 XHP70.3 has been on the market for so long, but we can only buy white light.
no ,Affected by voltage and internal resistance, as well as temperature control, the current actually drops very quickly.
About one month ,and new version has spring.
Thickness 15-25 microns, hardness about HV400
I’d be interested in lights with 90 cri versions, if available.
Correllux:Simon, do you know what the coating thickness is on the MAO finish for your lights?
Those look like numbers for type III hard anodizing instead of the MAO. Is that correct? I guess the thickness can vary but looks like the standard is from 25 up to 150. HV seems to be 600 on the low end up to around 1400.
