So, as promised, here are some beamshots from the Lumintop Frog, in comparison with other keychain flashlights.
First, I must say that the differences between using a 10180 or a 10440 or 3xAAA cells, on max (Turbo), aren’t very significative in terms of distance/range. They exist, they are visible as I’ll try to show below, but they are no very significative in terms of overal output. Maybe at close range there is more intensity, but at longer distances, it won’t matter that much.
My observations and opinion of the Frog in outdoor use are as follows:
- the range is not very long, the useful beam reaches 30m-40m max, independently of the battery configuration I was using
- the tint is very pleasant and good outdoor, not too warm, but not cold, and it mixes well specially in green environments (I don’t like it so much indoor)
- the beam shape is quite floody, although the hotspot has some definition, due to the type of TIR it uses.
In comparison with other keychain lights such as the Trustfire Mini X and the RovyVon A8, the beam of the Frog is better, more pleasant and reaches further distance.
In comparison with the GT Nano, it has obvious differences that I don’t need to detail, since the LED and reflector produce a very different type of beam.
Here are some of the beamshots for you to make your judgement!!
FROG
Trustfire MiniX > RovyVon A8 > LT GT Nano
FROG
FROG
FROG
FROG
10180 vs 10440 vs 3xAAA
@ 15 m > @ 45m > @ 55m
Now, some appointments on ergonomics:
And finally…the epic… Tales of the Frog
The Nightingale Frog and the Rose
Sempervium Frog
Echeveria Anura
The Grasshopper Frog and the Ants
Strawberry Fields Frogs Forever
The Frog and The Beetles
CatDog CatFrog
And that’s all frogs folks
