RD6012P feedback
The quality is good and the appearance is also very nice.
www.aliexpress.com/item/3256803286017579.html
RD6024 feedback
I ordered the complete set and another set of powerful wires. I assembled the power supply in one evening. It looks solid. Very convenient operation. The output voltage is regulated very precisely.recommend the product and the seller.
www.aliexpress.com/item/3256803558326998.html
RD6024 feedback
everything is great!
RD6024 feedback
Haven't tried it yet, but all is well. Came in two parcels. Everything is neat, nothing is broken
https://www.aliexpress.com/item/3256803558326998.html
RD6012P feedback
Item is as described, packaging and logistics are good.
http://aliexpress.com/item/3256803286017579.html
RD6018W feedback
Everything works as it should. Management is clear and convenient. You can either charge batteries or power anything. Enough power for almost any purpose.
https://www.aliexpress.com/item/1005001488070904.html
RD6018W feedback
The parcel was received at the highest level
https://aliexpress.com/item/1005001488070904.html
RD6006 feedback
RD6006 case made by a Baijiu metal box
https://www.aliexpress.com/item/4000282551930.html
RD6006 feedback
good, make the case with 3D printer
https://aliexpress.com/item/4000282551930.html
RD6006 feedback
good power supply with cable
today I got a dispute said that our USB meter cannot show current value, always 0, but his picture made me confused, he does not even connect a load, so how can this meter show you the current?
RD6012P feedback
This is my seventh order from the manufacturer. I am satisfied with the product, fast delivery - only 14 days, and also a gift!
https://aliexpress.com/item/1005003472332331.html
RD6018W feedback
Works well, CR1220 battery prepared by myself
https://aliexpress.com/item/3256801301756152.html
Why do the new power supplies for RD6006 have only 3 capacitors?
The older ones had 4
hello, are you sure RD6006 has 4 capacitors? becasue I check the original design, it only has 3 big capacitors, do you mean other models? or you can show us the picture
I saw 3 capacitors
