Those look like numbers for type III hard anodizing instead of the MAO. Is that correct? I guess the thickness can vary but looks like the standard is from 25 up to 150. HV seems to be 600 on the low end up to around 1400.
When I need try different Tir lenses I prefer have host with unscrewable head and integrated shelf similar T2 design.
(I would like if the mcpcb where even more raised to facilitate Led slicing)
The advantages are quick easy Tir Lens change, Led access and more space for larger drivers
than host pill based like S2+ where are necessary more operations and time.
Simon there will be a T2 style light 18650/350 compatible with threads and TIR lens used on S2+?
I don’t consider S3 for their recessed Led inside the head,a bit difficult for modding
Sorry, don’t understand this point. So, currently, Aliexpress has only 12FET+… options available. You say you’re not gonna sell 12FET, so, what does this option actually means then? 8A FET? 8A CC?
Yeeeees, a xhp35 S2 would be an awesome idea as well, even better than running a xhp50.
I wouldn’t complain about this option as well.
Xhp35s are awesome. I always wondered why they are not more popular, the xhp35 m21b sold out and never made a comeback.
If I could choose between a boost driver for S2s I would go for something to push a xhp35.2hi instead of the 6v for a xhp50.
But im getting whichever you make, I just need something special for my copper hosts : )
By the way Simon, I received my S2s and daaaamn I am blown away by the orange anodizing, wasn’t expecting it.
Thank you for that ; )
