Thanks, I remember Martin but had not seen that video and method for using a short stiff section of wire as a temporary switch and it worked successfully for me compared to trying to use the other end of a longer wire.
Too bad Martin (forum member M4D M4X) has not been recently active on this forum.
Yeah, wish he’d bop in as a member even if he was out of the sales game. His youtube channels are both still active, though, mostly Olight stuff in his native language.
My way was very similar to Matin’s video, except I only used a single piece of wire. I put one end on the battery and the other end on the inner tube plus momentarily on the outer tube to activate the switch.
1) No matter if the LEDs maybe burn due to too much current or bad soldering, I still think Wurkkos should change the driver to a linear design either way. It makes most sense for emitters like this, and who knows what super high drain cells may come in the future. Limiting the max output via a special firmware version might be a temporary solution, but linear drivers have more advantages other than "won't burn up emitters". Limiting the max output through the Anduril UI to avoid LED damage is very bad IMO, a light should never be left in a condition where it might destroy itself with a fresh cell after factory reset/default ramp settings in Advanced UI.
2) I still can't access the TS10 Aliexpress page from Germany. But at least now they are listed on wurkkos.com so that's good.
This is exactly what we want to do.
Or rather, we would love to do that.
For any interested flashlight enthusiast, we are welcome to contact us, then we will add some CSP2323 emitters to the parcel sent it for tests.
But sorry the number would not too much, because most of CSP2323 raw materials must ensure the normal supply of sale goods.
Sorry the champagne, purple, blue, green and grey these colors are on hold for now.
Because our PMC and warehouse partners were complaining that we made too many tags at the same time on TS10, which would affect the production and storage of other products.
Just for now, black+red+white, 4000k+6000k, red/blue/orange/green, we have 3*2*4=24 style models.
Including the allocation of raw materials, it is also necessary to re-run the audit meeting to make a decision.
We have ordered one set of new H10. It should be available tomorrow.
Then ready to find the specific reasons for this problem through a large number of samples collection.
I love how much you communicate about this, you're really doing this the right way. Other flashlight manufacturers should take notes on how to do this kind of problem solving.
Many thanks Jon. Hope you’re well. I haven’t been in for a while, we have pretty much zero data signal where we’re living in the camper, it’s both a blessing and a curse. Even a phone call involves walking up a hill to scrape a bit of signal out of the sky On the other hand, life is simpler surrounded by nature.
Torch ordered, and I threw in a silver with blue aux for good measure.
Finally got a TS10 and I have to say it’s the nicest cold white flashlight I’ve seen so far. Still have a cold white B35AM to reflow and compare, but these CSP emitters are quite nice. Still prefer warmer temps though Nice design as well, feels good in hand. Nicely done Wurkkos!
Thank you Streamtronics for your support always.
Everybody’s questions and suggestions are very precious for us, which will become Wurkkos’ power to move forward, make us higher, faster and stronger.
