thank you so much for your support , if you don’t more needs, it is ok, just help me to spread our products to let more people to know that
thank you again
@RD tech, do you think in the future, you could make something like an HD25/HD35 V2?
It would be the same product, but it would have undervoltage protection as well
I don’t know , but I will tell our engineer, when they design new products, they will consider this suggestion, thank you
I ordered a DPS5005 and DPS5020 with the cases and will power them both by a Meanwell LRS-350-48.
Any plans for a RD6024P?
so sorry, there is not plan for RD6024P
Right, right, the sales started.
yes, it lasts 5 days in total and there are 3 days left
Quick question, is there any difference between the 800W and 1000W PSU when it comes to high-frequency noise and (temperature controlled) fan speeds?
Also concerning the RD60xxP series. Is there are way to have USB from the backside? They have USB on the front, but maybe it’s possible to plug in a USB board instead of the Wifi board? And build a USB connector in the back of the case.
hello, 800W PSU may have high frequency noise when there is no load connected, it will dispear when there is load, 1000W PSU has no high frequency noise, it only has fan working noise
for the USB port, because the converter is used to inserted into a case, so only the front panel is available, so it is to meet the most customers request
Good to know, thank you! I’ll have to get the 1000W PSU then to go with the RD6012P. This fits in the S800 case right?
Just ordered a dps5020 and a dph5005.
What power supply do you recommend to use with the dps5020?
yes, 800w and 1000w psu are all sutiable for S800 case
you can find 60V 1200W psu, it will be ok
but we don’t have such power supply , but try to adjust lower 60V to be input
it is good time to take the RD6024 assembled set, the price is already lowest
https://www.aliexpress.us/item/3256804579174470.html
as mentioned many times, when you choose input PSU for our power supplies like RD6024 and RD6018, please choose PSU which has stable DC output, we already add input voltage protection board on our latest RD power supplies, but it is better to choose PSU with stable output
https://rdtech.aliexpress.com/store/1100599049
RK6006 DC to DC power supply feedback
nice power supply with good quality, and it is small sized, I will make the case for it
RK6006 Power Supply connection
hello, if you find device does not work normally, and you do not know what happen, just show us how you use the product, then we can find the problem, just like this RK6006 Problem, input voltage connects to output terminals, then it cannot work, but the device have protection,just connect it correctly and it can work again
The New Year Bliss Sale begins
there are 3 days left for the promotion, please notice that, if there is something you do not buy in your wishlist, it is a good time to make the order
https://rdtech.aliexpress.com/store/1100599049/pages/promotion-202312181222.html
hello, there are 2 days left for the new year bliss sale, please notice that, good time to order RK6006 and RD6024
