** BLF LT1M-Mini Project - The little Lantern! ( PM's sent today June 21, 2022)**
https://www.amazon.com/gp/product/B07RGF7WJ2/ref=ppx_od_dt_b_asin_title_s00?ie=UTF8&psc=1
This is amazon’s version of VHB. Just as good as 3M VHB but a fraction of the cost.
Thank you, I hadn’t thought of doing either methods, and certainly not having the magnet inside the tail cap! I’m actually from the UK, so I’ll try to find a UK source, for some reason, postage from the USA is usually way too expensive, even for something of that size. I would never have imagined that the magnet would work if put inside the cap! I may go through that route, the main reason I want a magnet for the mini lantern is so I can use it when I’m tarp camping and have nowhere to hang it, I’ll use a metal disk one the outside of the tarp and clamp the lantern to it on the inside, hanging down.
I’ve got a slightly thicker and stronger magnet coming in soon to try in the tailcap to see if it will reliably hold the light up on a vertical surface. Fingers crossed.
Guys, any one has manual for this LT mini? i cant seem to enter into Blinkies and Strobes mode unlike the LT 1.
Click 10x from off and hold the last click to ensure you’re not stuck in the simple UI, then try again. 3 clicks from off enters battery check on mine, just like full size. 3 clicks from off and hold the last one enters the strobe group on mine, just like the full size.
am interested for one please
Thanks much Grizzly! managed to get the manual from Barry.
Sorry for the manual was not included in the package.
click here to check out the LT1-Mini Manual PDF file.
Does anyone know if there’s a review video yet ?
It’s not a video but I’ve just posted my full review.
My order is about 2.5 hours away now, but it might take until Monday to receive it, lol.
Remember Monday is a holiday. So maybe Tue?
Very well done
Just recurved received mine , is very nice!
A big thanks to everyone involved for their efforts!
I finally found a magnet that works really well. D83-N52 from KJmagnetics.
For installation, just stretch the spring out a bit with some pliers. Be careful not to pull it out of its socket. If you do, it’s a little hard to get back in but it can be done. Then, just slide the magnet through the side of the spring and it will stay in place underneath it.
This setup is plenty strong and it can reliably hold LT1 Mini up on vertical surfaces.
I’m hoping some 3d’s a neat base for this and maybe glue a magnet into that
That gives me an idea. I could 3D print a wider base for my LT1 Mini, embed a magnet into it, and then use that magnet + the magnet in the tailcap to hold the wider base on.
If possible, print the base so that it can be stored atop the head when not in use. Like an inset ring on the bottom of the printed base that seats onto ring protruding from the top of the head.
Arrived today, so I ducked that problem. This light will get a lot of use! Thanks again to the team
