You probably aren’t going to get much interest in a twisty AA light. Your best bet would be to make an adapter sleeve for the C01S. Imagine a tube with threaded caps on both ends. The tail cap is a normal battery cap. The front cap has a threaded hole designed to fit the C01S head.
That said…. mechanical switches are now more reliable than the majority of twist switches. Twist switches have gotten much worse in the past 10 years. They now typically use PCB traces for 1 of the contacts instead of metal-on-metal. The PCB trace can wear down or tear out. (The C01S is like this.)
There are some good simple sturdy lights out there for reasonable prices. Looking over the inexpensive AA lights on the market finds a few promising options:
Or any mechanical tail switch could be replaced with a twist switch tail cap. If the threads are loose enough it can even still be used as a momentary pushbutton like the Gerber Infinity Ultra did.
A tail cap like that for the E2A would give you exactly what you are asking for.
I thought about the adapter. This idea is not new, old-timers like me might remember that this was a project for the ARC aaa flashlight 20 years ago (don’t remember if it has ever seen the day).
You are right Parametrek about the wear on the PCB but as mentioned, this is an emergency light. That switch should not be often used. The twisty switch is still in my humble opinion the most reliable circuit breaker. No parts, no spring, no plastic, no board, no rubber, no moving parts, less opening for water.
The Tool AA comes with both switches (clicky and twisty). However, a bit pricey and too many modes. I am dreaming of a refreshed version of the EZ AA from Nitecore,
No interest in twisties for me but you could put the magnetic tail cap on the Tool AA and it becomes a twisty light that way. Simon does have that little stainless steel AAA twisty model…could stand to upgrade the emitter in that one…has large grooves along the tube, not sure if those would match any trit or plastic glow tubes well.
Nextorch has something interesting but I doubt it has the quality you need:
- the LED is not High CRI
- it has 3 modes instead of 2 (not sure if it has memory or if it starts on low or High)
- runtimes are not specified
it is pricey
I will check if the C01S driver would fit the Tool AA V2.0 pill. If so, transplanting one from a light to the other would match your request.
I am not sure if the runtime on the C01S is similar to a “cockroach” light, though.
Another warning concerning the twisty lights: if a cell leaks on the bottom, it is a PITA to take it out (ask me how I know it )
All of those people that you mentioned in your family need a small EDC light ,with a lithium ion battery, a lot more than they need a so-called emergency light. Put a S2+ in your glove box for 5 or 10 years and it’ll still give you more light for longer than what your envisioning. If you want it smaller than that put the short tube on it.
I hear you. They all (except my mother) have an A6 as their main light when we go trekking or camping. However, the grail light I’m talking about is small, cheap and ultra-reliable. A kind of light you toss in your bag and forget it until you need it, not an EDC.
My (basic) understanding of a twisty switch tells me it necessitates either a spring or a rubber/ foam piece to push the cell back to reliably break contact without flickering. Ive only had a few twisty switches though so maybe some are different?
Some have a spring in the tail (like the C01S), some don’t.
If a Twisty light is unreliable, then it has been poorly machined or it’s a driver problem. Beside a bad thread, there is virtually no way a twisty switch can fail.
It sounds like the A6 is a special events lights not an EDC. Is this your Grail light your or theirs? You have to work with them to find something that they are willing to carry with them everyday and potentially use rather than their phone light.
You nailed it, using their phone light is exactly what I wan’t them too avoid. Too unreliable. Have you ever seen a teenager that has more than 15 % of battery on their phone ?
I’m not looking for an EDC light. My wife and daughters never carry an EDC light, I’ve tried to convinced them but you know, I’m a weirdo for always carrying a light ( :person_facepalming: ). That’s why I would like them to have at least an emergency light in their bag/purse that can give them many hours of light.
Why not just go with a Convoy T3? A mechanical switch is perfectly fine overall if configured with simple modes.
Efficient driver, relatively inexpensive, etc.
Also, please let’s stop asking for new light designs. Let’s just try and reuse current designs because Sofirn’s 2 engineers are already overworked as is lmao.
So yeah, let’s change try and get Sofirn to reuse a current light design to make this project a thing.
The Tool AA is 12USD on AliExpress. Seems reasonable to me.
I prefer the Skilhunt E2A with an Energizer L91 as my emergency backup light in my car. Simple 3-mode with memory. Set it to the middle mode, throw in the glovebox and forget about it for years.
(weight) One issue with AA lights is their weight. AA lights are usually more than twice as heavy than AAA lights. For your purpose, I think AAA lights would be much better choice despite shorter run times.
(cheap prices) I think cheap price is possible only if mass produced. But the features you want do not seem to attract the masses, therefore I think it is hard to achieve.
How about Nitecore MT06MD? It is pen shaped thus easy to carry along with other pens. High CRI Nichia 219B 5000K. Longer run time than single AAA lights. One bonus. Its head is compatible with Tool AAA, so if you want smaller light you can use Tool AAA’s tube since it can run with a single AAA.
