If you haven’t purchased the LightMaster 2 yet, wait it out some. Their prices seem to wander and being this is a new release, the LMPro price is steep. I got mine for ~ $21 USD after some 4 months this thread first came by. I had missed an opportunity somewhere after 2 months, but it does go ‘yoyo’.
As Jon pointed out, we find different uses for the device, none that we had ever forethought of. I too check on the overhead lighting and some of the crappy lights in my “lost” drawer. The Flicker index is not critical but useful.
Thanks so much for the tip. I think I will hold off and do that. If I do see it come up again for $20-ish bucks or so, then I’ll see enough value in it for me. Right now I can wait and not feel like I’m missing anything. Thanks again
Was wondering if there’s any difference between 2 and pro hardware wise. Some searching on the net revealed the following.
Series 2:
Pro:
They seem to use an entirely different sensor and controller/BT interface. Series 2 sensor looks a bit like an AMS TCS34903FN (red, green, blue, clear and IR), but could be something else entirely as well.
Does anyone ( @jon_slider ?) have Opple reading of Nichia 519a 4500k’s Duv (before dedoming)? All my other Nichia LEDs’ numbers are fairly consistent with known specs, except the 519a is unexpectedly giving a negative Duv even with several rounds of testing. That surprises me as numbers from Simon/Convoy indicate it “should” be positive.
OTOH looking at the color of the chart below, it does seem consistently accurate to what I see. More yellowish than magenta’ish and hugging BBL closely.
You left out some info which generally effects measurement of LEDs quite a bit: tir optic/reflector/bare led? what current are you measuring the LED at?
Without that info your measurements are close enough to my own (also from Convoy) to be believed.
Thanks - good points. I tested with Sofirn clear optic but didn’t think about bare LED. Now that I know what’s involved, will be more complete next time.
519a 4500k in Convoy S21D with Sofirn Clear Optic (the OEM frosted optic’s numbers didn’t change much). Tested at center of beam. 100% Brightness: Duv –0.0037 20% Brightness: Duv –0.0019. Other runs ranging –0.0020-0.0030
CCT similar to yours ~ 4100K
I have the old colormunki photo from this link. I got mine used from ebay. AFAIK it’s the cheapest way to get a real spectrophotometer. However once you see the cri and spectrum of a specific CCT of LED the opple seems to give you a ballpark of everything else that varies more.
far superior to Opple as colormunki has full CRI data, including CRI R9 and R12, and is more accurate overall.
but afaik, colormunki requires pairing with a computer and special software… Probably good for people that use PCs and command line interface… I dont know if it runs on a Mac…
