Quick question, is there any difference between the 800W and 1000W PSU when it comes to high-frequency noise and (temperature controlled) fan speeds?
Also concerning the RD60xxP series. Is there are way to have USB from the backside? They have USB on the front, but maybe it’s possible to plug in a USB board instead of the Wifi board? And build a USB connector in the back of the case.
hello, 800W PSU may have high frequency noise when there is no load connected, it will dispear when there is load, 1000W PSU has no high frequency noise, it only has fan working noise
for the USB port, because the converter is used to inserted into a case, so only the front panel is available, so it is to meet the most customers request
as mentioned many times, when you choose input PSU for our power supplies like RD6024 and RD6018, please choose PSU which has stable DC output, we already add input voltage protection board on our latest RD power supplies, but it is better to choose PSU with stable output https://rdtech.aliexpress.com/store/1100599049
RK6006 Power Supply connection
hello, if you find device does not work normally, and you do not know what happen, just show us how you use the product, then we can find the problem, just like this RK6006 Problem, input voltage connects to output terminals, then it cannot work, but the device have protection,just connect it correctly and it can work again
there is discount and instant discount now for the products, if you make the order now, you can enjoy these discount, the price is lower than normal price
