Hank_Wang
(Hank Wang)
July 1, 2022, 5:54am
5247
It does work actually, only that the moon mode is just too bright, almost like medium mode, so, you can only ramp from medium to high mode, other than that, it works fine, I assume it’s because of the low VF.
One resistor needs to be changed for the output voltage to swing across the lower voltage range of red LEDs. The current range is about 8.5V to 14.5V (simulated with the resistor values), fine for white LEDs but doesn’t go low enough for red LEDs.
I talked about it in several comments in this Reddit thread
m03da:
The quartet has arrived!
Impressions so far: SST-20 DR are extremely red (duh, I know, it’s my first time though).
A pleasant surprise is the boost driver’s moonlight (1/150), it’s wavering and fluctuating a bit but overall it gets much lower down than the dual channel linear, almost comparable to PL47G2, the queen of moonlight (out of my collection at least).
Remember that there is custom firmware to lower the moonlight on dual channel lights. D4(S)V2 - Lower Lows by Firmware
m03da
(a bear.)
July 2, 2022, 12:05am
5250
I’m aware and have flashed it to all of them later, I meant to compare the stock capabilities.
Thanks though!
supreme
(supreme)
July 2, 2022, 1:05am
5251
Anybody baked the 26800 tube? Didn’t realize these were darker than previous grey D4Sv2
Wondering if baking would make it lighter and almost match
ArtieT59
(ArtieT59)
July 3, 2022, 12:02am
5252
Hank-
What is this I hear, you are bringing back the EMISAR D1?!
or just a new 18650 side switch thrower?!
please share?
I am VERY excited about this. Some Reddit users and I have some questions if you don’t mind, Hank.
Will it come with the new body tube & magnetic tailcap available on D4V2, DT8, and DW4?
Will the head be the exact same design or will it be changed?
Will it have all the same emitter options as KR1?
Will it have a lighted switch option? If so, will it be standard or only via email request?
Hank_Wang
(Hank Wang)
July 3, 2022, 3:21am
5254
tactical_grizzly:
Yes, the body tube and magnetic tailcap are the same as D4V2, DW4.
The design has changed a bit, including the threaded retaining ring just like DW4.
Yes. it will have the same emitter options as KR1.
The lighted switch options are standard, alone with the SS bezel.
SKV89
(SKV89)
July 3, 2022, 6:38am
5255
So even China won’t ship to Russia now? I didn’t think China would cave-in to pressure from the West. Interesting.
ArtieT59
(ArtieT59)
July 3, 2022, 10:11am
5256
Hank
when could we expect the "new D1" to be available on website?
m03da
(a bear.)
July 3, 2022, 10:47am
5257
oooh, oooh, could the D1 v2 have a K1-style RGB switch backlight in lieu of RGB aux?
m03da
(a bear.)
July 3, 2022, 1:27pm
5259
Also general Hanklight question, can the aux emitters be swapped for different colours for added funk?
ETA: I’ve checked and they’re RGB packages, nevermind.
rjkesler
(rjkesler)
July 3, 2022, 1:35pm
5260
m03da:
That’s great news! Where did you look? Just so I know where to look in the future…
m03da
(a bear.)
July 3, 2022, 3:12pm
5261
I’ve looked through my DM11’s TIR. At the right angle it presents a magnified, sufficiently undistorted image of the aux emitters.
Yeah, I thought Russia and China were buddies.
The fact that Hank cannot deliver orders to Russia does not mean that China has stopped trading with Russia. Of course there are difficulties, but China has not turned away from Russia.
Are there any new novelties planned at Hank’s, does anyone know?
id30209
(id30209)
July 6, 2022, 12:42am
5264
Yup, D1v2 announced and as Hank said it will be available next week
Will B35 be available in D1 or DM1.12?
