This one is just a sample.
Simon Mao: snfx:Hi Simon, is it possible to build a MAO S2+ Triple LED with 18350 tube + TIR Lens?
i dont have 20mm carclo triple lens ,sorry
Will there be MAO S2+ 18350 tubes available?
Sorry, I don’t have this plan.
Simon! Any eta on brass or copper T3? You would probably sell 50 of them on the first day. Just from this thread
trakcon: Simon Mao: snfx:Hi Simon, is it possible to build a MAO S2+ Triple LED with 18350 tube + TIR Lens?
Oh no, that’s bad news to me as I intended to rock it only as an 18350…
How about the Ti version? are you gonna produce the 18350 tube? Any update on when the Ti version will be available?
Simon Mao:Just a sample ,i will produce MAO C8+
Hi Simon, but there will be also old style C8 in MAO finish or just that sample?
I would like an old style C8 in that color.
Second that motion :innocent:
… is the T4 reflector the same size as the S2+ reflector? Or to say it otherwise, can I install an S2+ compatible TIR lens inside a Convoy T4?
About ∅20 × 12 mm TIR lens for T4, like the S2+? Can you confirm, Simon?
Thanks! :-)
Guys, i’ve purchased a 4500K 519a S2+ a little while ago and it’s lens had a blue/turquoise reflection, i assume its the new coating color Simon is using.
I’ve made another purchase of a couple S2’s recently, two 519a’s and two copper hosts and none of them had coated lenses, did i get an old batch?
i don’t know, i have:
1 copper with green or turquoise reflection
3 old S2+ with violet reflection
Funny, my S2s lenses have no coating at all
Will the MAO s2+ feature a metal or rubber button? I strongly prefer the rubber, and I don’t want to drill out the host just to add one.
Agreed. I want to be able to use lighted switches in them.
I also strongly prefer the rubber switch. I can install a forward clicky switch under a rubber boot but not under a metal boot.
+1 on rubber switch. The metal switch is too sensitive and I often change modes accidentally.
Always with rubber switch. Better feel and more soft to press (ideal for me).
I have ordered copper material, but the date of completion is uncertain.
Simon Mao: trakcon: Simon Mao: snfx:Hi Simon, is it possible to build a MAO S2+ Triple LED with 18350 tube + TIR Lens?
The date of completion has not yet been determined.
Bsrkuti:… is the T4 reflector the same size as the S2+ reflector? Or to say it otherwise, can I install an S2+ compatible TIR lens inside a Convoy T4?
Thanks!
yes
it should be light green coated , just not so obvious
yes, rubber
I'd love to have a pebbled TIR optic inside a T2 or T3, I prefer those a lot over reflectors for very close up stuff.
