ACEBEAM New X75 80,000Lumens Brightest Power Bank Flashlight
89 posts / 0 new
ACEBEAM
ACEBEAM's picture
Last seen: 6 days 9 hours ago
Updated 2022/8/27
ACEBEAM X75 Limited Edition Off-White Micro-arc Oxidation (Available on 15th Sep)
The X75 High Performance Outdoor Flashlight achieves IP68 waterproof rating, can resist 1 meters impact, is rugged and durable, can meet different needs of lighting situations, and is your outdoor lighting reliable partner.
Learn more: https://www.acebeam.com/x75 ________________________________________________________________________________________________________________________________________________________________________
New Announcement: The Acebeam X75 is Brightest Power Bank flashlight in its class ( built-in 4 × 21700) , and the flagship flashlight of the Acebeam X series. Also the new X75 is the world’s first USB PD flashlight with supporting 100W rechargeable system which saves you more time. After more than 1 year of development, our innovative development team has worked tirelessly to optimise the efficiency of the circuit up to 98% in order to produce as much light as possible.The X75 is a rechargeable searching LED flashlight with delivering astonishing 80,000 max lumens, a wide beam angle momentary Turbo and strobe function are quite ideal for security, law enforcement,search and rescue.
Lighting up a park!!
Features:
1) 80,000 lumens max output.
2) USB Type-C PD60W fast charging (Standard); 1.5 hours for full charging. Also can compatible PD100W fast charging(Max); 1 hour for full charging.
3) Built-in dual intelligent temperature regulation systems.
4) Intelligent cooling fan and Intelligent thermal control module.
5) Detachable, maintainable and waterproof cooling fan(IP68).
6) Can set the Windy mode or Non-wind mode.
7) Up to 98% high efficient constant current circuit.
8) Momentary Turbo activation rapidly responds to emergency situations.
9) Pure copper heat dissipation piece for high efficient heat dissipation.
10) Color-changing silicone sleeve monitors the temperature of the flashlight and protects for anti-impact.
11) Patented mechanical safe lock – No accidental activation.
12) IP68 standard waterproof.
This new X75 is the built-in battery pack (4 × 21700 ) brightest LED searchlight, features 12 CREE LEDs, and along with a wide reflector it produces an unprecedented 80,000 Lumens!
The X75 High Power flashlight utilizes boost circuit; innovative intelligent cooling fan for efficient heat dissipation, scientific cooling air duct design, detachable and maintainable cooling fan, and Type-C PD60~100W charging/discharging function – a truly uncompromising solution for the demanding professional user.
This tremendous power is focused through that reflector and can reach distances of up to 1150 meters (3773 feet), perfect for long range spotting as well as intense search and rescue operations.
Edited by: ACEBEAM on 08/27/2022 - 06:33
alumenum
Last seen: 1 hour 1 min ago
What is the throw/candela?
Th558
Th558's picture
Last seen: 15 min 50 sec ago
What in the world…Can I have a 90% discount Big Smile
Th558
Th558's picture
Is there going to be a HI version?
will34
will34's picture
Last seen: 1 hour 45 min ago
I hope you could release a flashlight of a similar form factor that is designed to perform in real world scenarios instead of achieving absurd lumen claims. Above 10,000 lumens or so, the effectivity of the beam only gets worse the higher you go due the light scattering and bouncing back.
At maximum output one would need to wear sunglasses to operate the flashlight.
SKV89
Last seen: 19 hours 17 min ago
The light looks nice. Which emitter? The XHP70.2 or XHP70.3 or XHP70.3 HI and what cct?
Funtastic
Funtastic's picture
Last seen: 42 min 43 sec ago
70.2 6500K with 5000K coming soon.
Piercing The Darkness YouTube channel – https://www.youtube.com/c/PiercingTheDarkness
Fedtro
Last seen: 4 hours 38 min ago
Personally I think it is a light with many shadows starting from the Fandle handle that is absolutely useless, produces a cooling close to zero and I say this as the owner of a Manker MK38, the only usefulness is not to burn your fingers, beyond this we want to talk about the lumens declared? It is not possible to have 80000 lumens from 12 xhp70.2 with that battery configuration and I speak as an owner of Imalent MS12 mini who has 60,000 real ones with the same battery configuration, also I believe that by now customers are fed up with these series flashlights: "firepower is never enough ..." much better a hybrid like Imalent MR90 that combines Flood and Throw for superior usability but above all with a better cooling and runtime, this time Acebeam could dare something more in innovation instead they preferred to focus on the large numbers of the 80,000 lumens declared following marketing rather than technology. Very disappointed with this product if it is true that they have been working on it for more than 1 year, they could have used their time better IMO.
optntdr13
Last seen: 1 week 4 hours ago
Why not 70.3 HI Hi CRI? Missed opportunity.
hIKARInoob
hIKARInoob's picture
Last seen: 1 hour 10 min ago
Good job Acebeam! Very interested in test results! Cool
Fedtro
[quota=Fedtro]
Personalmente penso sia una luce con molte ombre a partire dal manico Fandle che è assolutamente inutile, produce un raffreddamento vicino allo zero e lo dico da possessore di un Manker MK38, l'unica utilità è non scottarsi le dita, al di là di questo vogliamo parlare dei lumen dichiarati? Non è possibile avere 80000 lumen da 12 xhp70.2 con quella configurazione batteria e parlo da possessore di Imalent MS12 mini che ne ha 60.000 reali con la stessa configurazione batteria, inoltre credo che ormai i clienti siano stufi di queste torce di serie: "la potenza di fuoco non basta mai..." molto meglio un ibrido come Imalent MR90 che combina Flood e Throw per una fruibilità superiore ma soprattutto con un raffreddamento e una autonomia migliori, questa volta Acebeam ha potuto osare qualcosa in più nell'innovazione invece ha preferito puntare sui grandi numeri degli 80.000 lumen dichiarati a seguito del marketing piuttosto che della tecnologia. Molto deluso da questo prodotto, se è vero che ci hanno lavorato per più di 1 anno, avrebbero potuto usare meglio il loro tempo IMO.
Since I am not a person who criticizes without proposing something constructive and I love you because I have several of your flashlights or K75, X65 mini, X70, X80GT etc., I want to suggest a new product with a very competitive cost and that could have many admirers. , take the head of an X65 mini replace the LEDs with Luminus SFT40 and update the battery pack with 3x 21700 and maybe even add a usb-c recharge even if it may not even be necessary and you will get a flashlight with at least 12500 real lumens and a throw of at least 1800 meters which will outperform almost all medium launchers with SBT90.2 and in addition you will get a very good runtime because the SFT40 is less thirsty than energy and heats much less than an SBT90.2
[/Citazione]
Cochise334ever
Cochise334ever's picture
Last seen: 1 week 1 day ago
Never had and never wanted a flashlight with propriety battery pack. What’s that cost $150 to $200 to replace it? 80,000 lumens for what 10 or 20 seconds?
I’ll stick to a few of my lights that can sustain about 10,000 lumens until my hand tells me otherwise!
To admit is to acknowledge.To Accept is to take action.
Funtastic
Funtastic's picture
Excellent for users who don’t want to fuss with buying individual cells though. No different to buying most mobile phones these days with a built-in battery.
Sorry readers, this discussion went a bit sideways from here on. I should have just stopped responding. Plain and simple, some people don’t mind a propriety battery pack and some people hate them, like Raccoon City…lol
raccoon city
raccoon city's picture
Last seen: 51 min 57 sec ago
Location: Palm Desert CA ~ West Coast is the best coast
Never had and never wanted a flashlight with propriety battery pack. What's that cost $150 to $200 to replace it?
Excellent for users who don't want to fuss with buying individual cells though. No different to buying most mobile phones these days with a built-in battery.
That's great for you, Funtastic.
Buy every flashlight with a proprietary battery that you can find.
As for me, I'm not touching any of them with a ten foot pole if I can help it, except for maybe keychain flashlights.
They're extremely expensive to replace.
They do make flashlight companies a boatload of money, though.
Oh, and my cell phone has a very inexpensive battery, thank you very much.
I'll be avoiding cell phones with extremely expensive batteries as well.
I'll try to spend my money wisely.
You can waste your money all that you want.
(And I thought the recent Beavis and Butt-head movie was really stupid.)  :FACEPALM:
Funtastic
Funtastic's picture
Never did I say I was a fan of a propriety pack. i simply said that they're great for some users....I know for a lot of people who aren't enthusiasts, they'd be more interested where they don't have to worry, just buy another pack and they're away.
Same with anyone who has a drone, you can't just go get any battery and chuck it in. My DJI drone costs me roughly $300 nzd for a battery and I'm happy with that, it's just one of those things...
Funtastic
Funtastic's picture
I’ll be avoiding cell phones with extremely expensive batteries as well.
It isn’t the battery that’s often expensive, it’s the labor.
Everything is heading to electric powered, soon you won’t be able to avoid buying a car that doesn’t use a propriety pack lol
raccoon city
Funtastic wrote:
raccoon city wrote:
Oh, and my cell phone has a very inexpensive battery, thank you very much. I'll be avoiding cell phones with extremely expensive batteries as well.
It isn't the battery that's often expensive, it's the labor. Everything is heading to electric powered, soon you won't be able to avoid buying a car that doesn't use a propriety pack lol
I replaced my cell phone battery all by myself.
Total labor cost: $0
I swear, defending proprietary batteries on budgetlightforum doesn't make any sense.
Funtastic
Funtastic's picture
Wow mate, can we keep this friendly? No need to start calling me stupid. You should well and truly know the rules of this forum by now…
raccoon city
Dude, you're defending proprietary batteries on budgetlightforum (and this isn't your first time doing that.)
Don't you see the paradox there?
And I didn't call you stupid.
I was talking about your actions.
There is a big difference.
Funtastic
Funtastic's picture
Have a good night mate. It’s a forum, we all have an opinion…sucks to think that someone gets attacked for sharing one that another doesn’t agree with
raccoon city
Once again, you didn't get attacked.
But, good night to you as well.
Funtastic
Funtastic's picture
Quote:
I’ll try to spend my money wisely.
(And I thought the recent Beavis and Butt-head movie was really stupid.) Facepalm
Not exactly the most friendly approach.
Just to end I would like to be clear that all I’m saying is that some people like a built in pack, that’s all. If I have the choice, I avoid them. For my new DJI RSC2 gimbal I just purchased, it has a built in battery which is not amazing, but that’s one of the reasons I have a $300 kweld spot welder, so I can replace it myself, if needed.
raccoon city
Riddle me this:
Why would you repeatedly defend proprietary batteries on budgetlightforum if, when you have a choice, you avoid them?
That doesn't make any sense.
Funtastic
Funtastic's picture
raccoon city wrote:
Riddle me this:
That doesn’t make any sense.
I have an online business selling flashlights and you wouldn’t believe how many muggles love to not worry about batteries. They’re happy to buy another pack and away they go. LED Lenser are New Zealand’s number one brand and most use a propriety pack, yet they’re always recommended despite this.
raccoon city
Funtastic wrote:
I have an online business selling flashlights and you wouldn't believe how many muggles love to not worry about batteries. They're happy to buy another pack and away they go. LED Lenser are New Zealand's number one brand and most use a propriety pack, yet they're always recommended despite this.
Yeah, you don't have to "worry about batteries" until you have to replace them for an arm and a leg.
This is budgetlightforum where you are defending proprietary batteries--not your online business.
Do you still not see the paradox?
Pöbel
Pöbel's picture
Last seen: 6 days 13 hours ago
but it requires you to have the skills. Same is true for the pack. Its more involved than swapping a cellphone battery, but it is as doable if you got the skills and tools.
The common muggle will neither replace his cellphone battery nor the cells in a pack like this one.
raccoon city
Pöbel wrote:
but it requires you to have the skills. Same is true for the pack. Its more involved than swapping a cellphone battery, but it is as doable if you got the skills and tools. The common muggle will neither replace his cellphone battery nor the cells in a pack like this one.
Replacing the battery in my cell phone was super easy and required no special skills.
There are cell phones out there with inexpensive batteries that are super easy to replace.
And there are tons of flashlights that have super easy to replace batteries that are inexpensive as well.
raccoon city
Funtastic wrote:
Plain and simple, some people don't mind a propriety battery pack and some people hate them, like Raccoon City...lol*
I would bet that most people on BLF avoid proprietary battery packs like the Covid.
Not many informed consumers want to pay an arm and a leg when their proprietary battery pack fails.
Cochise334ever
At Raccoon city…a Present from my morning hike the other day.
There were four of them. You can see all four of them in the last photo.
Two of them with their back towards me.
netprince
netprince's picture
Last seen: 4 hours 26 min ago
No propriety battery pack lights for me
Rob0915
Last seen: 2 months 7 hours ago
I’m not buying any light with a battery pack. The battery pack is the first thing that breaks and wears out. Also I use the same set of batteries in multiple lights, why buy new batteries with every light?
