ALL THINGS BUDGET KNIVES
I've had good results from FLITZ ...might be worth considering
Flitz is great for getting rid of rust and pepper spots on non stainless steel. Bar Keepers Friend is also good for rust also.
On my non Stainless knives, I usually will coat the blade in froglube and let it sit for a while before wiping it off, seems to give some protection to the metal later during use, if the knife will sit or be stored I coat it in wd40 specialist corrosion inhibitor.
For cleaning CLP or froglube work well
And for light specks of rust, flitz is good.
I forgot to mention I also give my knives a light coating of Camellia oil after a Flitz polish....acts as a rust inhibitor too
xevious….
try Fine Brass Wool.
just like steel wool
but softer scrubbing.
Sounds like Flitz is the popular solution. Will be getting some. The silver polish worked and so far the stains are not returning but it did require a few passes to finally clean them off.
Hey TD, I’d never heard of brass wool before. Sounds interesting & will make a point of picking up some — thanks!
Froglube sounds interesting, PT. I wonder if it’s anything like naval jelly? I do liked the idea of being proactive & putting on some kind of coating periodically to reduce staining of D2 blades.
I don’t think that frog lube is very similar to the naval jelly.
Frog lube is a bio based product and it’s food safe.
It’s sold as a eco friendly gun cleaner and lube
“Navl Jelley” is a rust remover, it does not prevent rust.
I think Naval Jelly and Coke or Coca Cola, have Phosphoric Acid,
Here is a nice video comparing a few rust removers:
You are correct on the Naval jelly but Coke (coca cola) is Carbonic acid from the carbonation.
Coke, Pepsi, and a few other sodas do in fact contain phosphoric acid. It makes them more acidic than what you’d get from just the dissolved carbon dioxide in plain seltzer.
Hello guys and girls.
My review of the most extreme parts of the Brother brand!:
Chinese Knives: Quad review: Brother 1615, Brother 1605, Brother 1612 and Brother 1603
Civivi Relic
You already know that I loved the SRM 7228, you have it reviewed both on my blog and on my YouTube channel, but I always thought that I would love to have the same model in a larger size.
Well that time has come…
I hope you like the comparison.
Link: https://chinese-knives.blogspot.com/2022/10/review-srm-7228l-gw-vs-srm-7228.html
Well, it was time for the review of this SRM model, which is quite popular for its appearance :sisi1:, I’m always attracted to “clip point” and “tanto”:.
Link: Chinese Knives: Review SRM 9201
Honestly, I just leave the stain on there. I don’t consider myself a knife collector though I do have more knives than I care to mention. My knives just like my guns, tools, flashlights etc…. Get the living hell beat out of them. The function of all of those tools are flawless but I don’t get bothered by a superficial blemish’s. It’s not to say I don’t care about them or care for them but, they are all tools first and everything else second.
Anyone else like that or am I alone in this one?
well, sort of similar….flashlights and knives especially.
with guns, walnut stocks deserve attention, and the bore
gets some too, but in general, tools; like you said.
I’d just worry about that stain “anchoring” itself for rust to return faster. I don’t mind a little extra effort to keep the blade clean. And for one a blade that will get a lot of moisture exposure, I’d pick S35VN.
since anything over $19 is not “budget” for me….
here is a $10 one i got off Craig’s List:
I see your point. No use letting rust take over for good if you can actually prevent it. I usually end up losing knives before they get time to rust. :smiley:
Not a huge D2 fan. My Wesn knife that I seem to use the most is S35VN and seems to take a pretty good beating, keeps an edge for a while and yes, no rust.
