OK, so I’d been using my stubby (18350) FW3A with only a few hiccups… had to loosen & re-tighten the head to clear that peculiar auto shut-off when ramping up, just a couple times over the past 2 weeks.
Last night I’d used it a bit. No problems. Set it on my nightstand pointing towards me so I could see the GITD insert… and at about quarter to 6 am, I open my eyes to a blinding bright light. My FW3A had turned itself on & auto ramped to maximum!
I was lucky that I wasn’t in a deep sleep at that point and woke up in time. The head was almost too hot to touch and the table had a hotspot where the head had rested. Switch was inoperable. I unscrewed the head and cut power. Fully tightened the head & proper function was restored.
I wonder, if I did a software lockout would this have still happened?
I’ve never had this trouble with my full size FW3A (18650), just the use of the 18350 tube.
Anyway I’d forgotten to apply the kapton tape I mentioned back in April. Definitely going to give it a try now… Hopefully I can find the stuff! (My junk drawer situation is a bit fubar)
Definitely sounds like the signal tube accidentally shorted. With that short, the driver thought you were holding the button down so it ramped up to turbo and stayed there.
Some tips:
Remove, clean everything, reassemble. Check alignments when reassembling.
Make sure the tailcap retaining ring is slightly loose. That ring is just there to prevent the tailcap guts from falling out. If you leave it a tiny bit loose the tailcap pcb is able to free-float and may actually connect better to the signal tube.
You can prevent the issue of accidental ramp-up burning a hole in your desk by reflashing the firmware to upgrade from Anduril to Anduril2. Anduril2 has a safety feature to prevent this kind of thing happening. With Anduril2, if your signal tube malfunctions and the light ramps up to max it will pause there a couple seconds then ramp back down to min, turn off, and put the light in lockout mode.
That sounds quite unacceptable to me and a bit dangerous. My old man response would be to either retire that light (remove battery) or else return it to the original 18650 tube. I guess I no longer have the patience to do a bunch of investigating and repairing to make it reliable.
Barring a software bug or unlikely corruption of the ROM, software lockout should guard against this. Given the flaky nature of the FW3As switching I use it whenever it’s not in my hand. Thankfully I’ve only had issues with it activating while clipped to a pocket whenever I’ve neglected to lockout - presumably because that switch is all too easy to bump.
It is an early one. In particular, this is the one with the ToyKeeper icon on the switch. My full size 18650 had this same trouble very early on and was resolved after cleaning and reseating the tube. Hasn’t happened again since.
Thanks. I did clean everything before, which should’ve taken care of the problem… not sure how to “check alignments” as I can’t see inside the tube when closing up. But I did not know about that tailcap retaining ring tip. This one does have a retaining ring, unlike my other FW3A. One of these days I will see about flashing firmware, but right now I’m not set up to do it. Good to know that Anduril 2 has a failsafe to mitigate that problem!
Hi everyone! I’m new here, but reading quite a while.
Just got my fw3a sst-20 4000k from aliexpress and wonder how to check did I have a “full version” with all the power channels or missing some.
Head inside looks just like on the left (I mean photo in the first post). What else can I check?
Mainly just count all the 7135 chips. There’s 6 on the back and 2 on the front, but the front side might require unsoldering the 2 main wires to look at it. You can check that the brightness when ramping up or down is smooth.
There should be a short dip in power as you ramp between the 7135 chips and the FET. The newer firmware might be different though. Let’s see what other folks say. (My light is a very early one)
All 6 are in the back, but don’t want to unsolder anything to count those on the front.
Ramp is all smooth and there are two ‘blinks’, one on the high and one in somewhere in between.
I checked mine. When ramping up there are two short blinks. One when it switches from channel 1 to 2 and another from 2 to 3.
I’m still not sure that’s a guarantee you have 3 channels in yours. I’m not even sure which software version your light has. Hopefully someone can give you a more concrete answer.
If the ramp is smooth I wouldn’t even worry about it.
