【convoy】M21G XHP70.3 HI 2*21700 flashlight available
8772 posts / 0 new
Simon Mao
Simon Mao's picture
Last seen: 19 hours 21 min ago
Thom986 wrote:
Hi,
I have a little question.
I want to change a lens on a S2+ with 519A.
I’m not sure about what to buy :
- https://fr.aliexpress.com/item/1577614278.html
- https://fr.aliexpress.com/item/1005001963140993.html
Thanks.
i recommend bead tir lens
https://www.aliexpress.com/item/1005001973468244.html
4x18a
4×18a mod SFP55 22.000 lumens , but at the moment driver max output only 18amps = 8000 lumens . Waiting for Simon produce 80amps driver so it can max 22.000 lumens
Original
Mod SFP55
Haukkeli
Last seen: 1 hour 32 min ago
Mod SFP55
Where did you find that monster?
4x18a
Haukkeli wrote:
Mod SFP55
My friend bring it from china . This is the new version of SFH55
LunaLoves
Last seen: 42 min 52 sec ago
4×18a wrote:
Haukkeli wrote:
Mod SFP55
You don’t happen to have a URL?
Asking for a friend Innocent
PyriteParachute
Last seen: 2 weeks 2 days ago
Mod SFP55
At least that driver is fully regulated at top brightness, something I wish was true of the L8.
tactical_grizzly
tactical_grizzly's picture
Last seen: 29 sec ago
PyriteParachute][quote=Haukkeli wrote:
Mod SFP55
Unfortunately 4×18A’s 3V driver (the one used in the SBT90.2 model which the user “4×18A” used) is not fully regulated on Turbo (see my regulation testing below). It’s fully regulated on all the other modes though, which L8 is not AFAIK.
L7 is fully regulated on all modes (see my regulation testing below), which is very impressive for the price. Not even Thrunite’s $250 TN42 V2 could manage that.
Haukkeli
I modified my driver to 25A output. TacGriz, did you use included Liitokalas on your testing? It could be that it is regulated, but battery voltage just sags enough for it to drop out of regulation. In my tests those Liitokalas give little over 7A in direct drive lights and 18A/4 is 5.5A. Maybe enough to cause voltage to sag.
Alen
Last seen: 1 week 1 day ago
Simon,
I want see which of these drivers is less bright.
Can you post a photo comparison between the13 group driver powered by Ni-Mh AA batt.
https://aliexpress.com/item/1005003374477862.html
and the 4×7135 new firmware driver powered by lithium?
https://aliexpress.com/item/32734523412.html
Both drivers set at minimum level brightness with same Led type
Thanks
4x18a
Could you please share how to mod 25A ?
Haukkeli
Just by lowering current sense resistor value. If you remove the driver it has 2 big resistors with R020 written on them. So 10mOhm for 18A. From there you can calculate sensing voltage. Knowing the voltage you just change the amperage to your desired value in U=RI equation.
U=10mOhm*18A-> U=180mV.
R=U/I-> R=180mV/25A-> R=7.2mOhm.
Edit: I have tested it to function with 25A, but there’s always risk for something to break.
4x18a
Thank you very much ! I have removed the switch and 2 screws but the driver still too tight can not get it out , I missed something ?
Haukkeli
Wires to led are holding it in place. And maybe to switch also.
4x18a
I removed all wires to led , switch , 2 screws but the driver still not move . Can you remember how to get it out ?
tactical_grizzly
I used NCR18650GA’s for my testing but I think your explanation is correct. As the cells are depleted, the voltage will sag lower, and eventually it sags lower than the LED’s Vf so you cannot get full brightness.
That’s been my experience with all the SBT90.2 lights I’ve tested that have one cell, or multiple cells in parallel. I think SBT90.2 is best driven my multiple cells in series with a high current buck driver like in Convoy L7.
Haukkeli
It’s probably just little stuck. There wasn’t any glue in mine. Try to wiggle it little from switch hole and usb-c port.
ArtieT59
ArtieT59's picture
Last seen: 23 hours 54 min ago
I couldn't agree more!
The L8 is definitely my favorite single cell sbt90 Light. I like everything about it, but the biggest drawback is the limited compatibility of a single 26800 / 26900. They're just not great cells for high amp sbt90 lights. I'd much rather the L8 head / Reflector with single 21700, 21700 in series or even 26800 in series if need be, and the appropriate buck driver of course (Side switch only). But, i still use the L8 daily and own two of them. One for each hand, of course.
[FLF] Five Light Friday https://budgetlightforum.com/node/78749
Check out some of my new lights (picture heavy) and quick first impressions of them here: https://budgetlightforum.com/node/77180
My Sft40 beamshots / comparison thread: https://budgetlightforum.com/node/78100
The BLF GT with SFT40 (2300lm, 2700m+ @ 30 seconds!)
https://budgetlightforum.com/node/79561
BlueSwordM
BlueSwordM's picture
Last seen: 1 hour 10 min ago
Or better yet, just use higher power cells like the Samsung 30Q or Molicel P28A.
The NCR18650GA is a 5-8A cell at best honestly, and going at 10A isn’t the best idea to get out most capacity out a high power LED.
Tatteredmidnight
Last seen: 18 hours 49 min ago
As someone mentioned above, at 18A, it should be pulling about 4.5A per cell, which may cause sag in an NCR18650GA, but should be well within its capabilities. Probably less at most voltages since it’s a buck converter and the vF is close to 3v, so at higher cell voltages, it should be pulling less than 4.5A for the driver to deliver 18A @ 3v.
Haukkeli
Even at 25A it’s only 6.25A per battery, which should also be ok for Sanyos. Sbt90.2 is about 3.6V on 25A if extrapolating from diagram. And GA’s drop to 3,8V at 7A current draw.
tactical_grizzly
4×18A’s driver is linear, not buck
Also, max achievable turbo brightness drops smoothly as the batteries drain so it makes sense that voltage sag is the cause.
Chinaheart
Chinaheart's picture
Last seen: 5 days 11 hours ago
Happy Birthday Simon Mao......Wishing you the biggest birthday celebration today, good health and more flashlights to build.
lg.tech
Last seen: 3 hours 50 min ago
Happy Birthday Simon!
Have a great day, cheers!
raccoon city
raccoon city's picture
Last seen: 22 min 38 sec ago
Location: Palm Desert CA ~ West Coast is the best coast
Happy Birthday, Simon!  ^:)
Superstocker
Superstocker's picture
Last seen: 2 hours 3 min ago
Happy birthday Simon! Thanks for your continued interaction with us. It is greatly appreciated.
Tatteredmidnight
I didn’t know the regulator was linear, touché. Still, worst case is 4 – 6A draw per cell. Voltage sag may still be the culprit, but well within the cells’ capabilities. Only way to know for sure would be to test with different cells and compare I suppose.
thefreeman
thefreeman's picture
Last seen: 38 min 45 sec ago
About 70~80mV higher with 30Q at 5A at high SOC, not a big difference but it can help a bit.
More importantly the 180mV drop across the sense resistor doesn’t help.
With 30Qs and a more reasonable 50mV Vsense, 0.2V would be saved, that’s significant.
Simon Mao
Simon Mao's picture
Alen wrote:
Simon,
Thanks
7135*4 is out of stock
Simon Mao
Simon Mao's picture
Chinaheart wrote:
Happy Birthday Simon Mao……Wishing you the biggest birthday celebration today, good health and more flashlights to build.
Although today is not my birthday, I still want to thank you all. Party
There’s an interesting thing in there. China has a lunar calendar and a solar calendar. Actually my birthday is counted according to the lunar calendar. Big Smile
NeutralFan
NeutralFan's picture
Last seen: 20 hours 18 min ago
When will the 23.2*1.4mm ar-coated glass lens ,suitable for Convoy S21A S21B be available with the new green AR coating?
I’d rather use my flashlight around the house than turn on the lights.
